lathe knurling tool
lathe knurling tool
Home Forums Beginners questions lathe knurling tool
Viewing 25 posts - 1 through 25 (of 29 total)
  • #532348
    Dale Parsons
      @daleparsons38290
      Hello all. Please could you share with me some of your valuable knowledge on this skill, I’ve had a warco 180 delivered and totally new to this, have been watching you tube vids and thought I’d try to make brass handles for the lathe as a start project.
      Could someone advise what lathe knurling tool I need to buy as there is so many and ones with more wheels than some
      I appreciate you taking the time to help a newcomer to this skill set
      kind Rgds
      dale
      Dale Parsons
        @daleparsons38290
        Advice
        #532355
        Journeyman
          @journeyman
          Basically 3 types (someone will be along soon to tell me I'm wrong).
          1. Push in
          2. Clamp
          3. Cut
          For a small lathe such as the WM180 probably better with the Clamp type as it imposes less strain on the bearings. The cut type are good but seethingly expensive. Have a look at this one from ** ArcEuroTrade **
          This article on making ** toolmakers clamps ** covers knurling in a bit more detail, about half way down the page.
          Edited By Journeyman on 07/03/2021 17:16:53
          #532356
          Frances IoM
            @francesiom58905
            the one with two wheels + a sisor like action to adjust to the bar and one that will fit in the tool post – the WM180 doesn’t have the power to handle the single wheel type nor is the tool post big enough to take most – I bought mine I think from ARC but WARCO do a similar type but even then needed to mill part of the holding bar to fit the 180.
            There are several designs that you can make yourself Warco sell the hardened cutters – there was an interesting design by Jacques Chirac? in one of the mags abt 3 years ago that used non bevelled wheels to cut rather than crush the metal
            #532364
            jon hill 3
              @jonhill3
              Why not make one, if you have some stock metals about there is plans for one in Harold Halls 'Lathework a complete coarse'. I think its workshop practice series no 34
              There are plenty of other interesting projects in the book too.
              Jon
              #532380
              Andy Carruthers
                @andycarruthers33275
                I bought scissor type and have good results from my WM180, didn't need to mill part of the holding bar though
                Recommend starting with soft material to practice on with lubricant, for me knurling is a confidence thing so I start with light clamp then tighten until I achieve the result I am aiming for
                An easy begiinners job is to replace the hand-dial knobs, plenty of operations to build confidence, I did mine in brass
                #532382
                Dale Parsons
                  @daleparsons38290
                  Thank you for your replies.
                  #532383
                  Dale Parsons
                    @daleparsons38290
                    Andy what size brass blanks did you buy / use for the handles.
                    #532390
                    Andy Carruthers
                      I had some brass offcuts lying around so used those, IIRC the handles ended up ~20mm in diameter, much more tactile than the originals not just because of the knurl, but also because of the diameter
                      #532484
                      Gary Wooding
                        @garywooding25363
                        **THIS** pdf describes a clamp type knurling tool that I designed and made many years ago. It gives full details and dimensions. It works well and I've used it many times.
                        #532489
                        Hopper
                          @hopper
                          Posted by Gary Wooding on 08/03/2021 07:27:39:
                          That looks like a beauty. The side plates look as though they would stop the problem of the two arms flexing out of line under heavy loading etc. Thanks for posting.
                          #532507
                          Dale Parsons
                            @daleparsons38290
                            Jon hill 3 thank you for advising on the books I’ve purchased both of them on Amazon,
                            Andy carruthers looked on eBay for some brass blanks can’t get over how expensive they are, think I’ll be going with aluminium lol.
                            thanks again for all your post.
                            #532508
                            bernard towers
                              @bernardtowers37738
                              Gary, very similar to the MARLCO which industry loved , I made the Hemingway version and have never looked back. Think it’s all down to the large side cheeks.
                              #532509
                                Nicely designed, and very clearly presented, Gary … Thanks for sharing it.
                                John Haine
                                  @johnhaine32865
                                  Just a small point, what do you intend to knurl? If you plan to make new handwheels for the lathe, bear in mind that knurling may be very uncomfortable on the hands after a short while as the surface can be rather sharp. Knurling is ideal for small knobs that aren't often adjusted, but with machine handwheels it can be better to have a smooth polished surface on both the wheel periphery and the handle. A nice rotating handle with minimal play is even nicer.
                                  #532521
                                  Nicholas Farr
                                    @nicholasfarr14254
                                    Hi, I have one similar to Knurling Tool I may have even got my one from them, but it was so long ago I can't remember, however it has worked satisfactory for my needs.
                                    Regards Nick.
                                    #532526
                                    Andy Carruthers
                                      John makes a good point, I recall someone (Hopper?) suggesting to run a file over the finished knurl to take the rough edges off, it has been a while since I made the handles
                                      #532530
                                      Hopper
                                        @hopper
                                        Posted by Andy Carruthers on 08/03/2021 10:42:22:
                                        Indeed it was. Was how apprentice toolmakers were taught to do it back in the ancient days of yore. A 10" flat single-cut mill file was the weapon of choice, used on the finished knurl spun in the lathe. Just enough to knock the sharp points and burrs off the knurls. Should be done as a matter of course on all knurling. Straight knurling works very well on things like cross slide dials and is easier again on the hands, after a touch up with the fine file. If you don't file it, a diamond knurl is basically like a rasp and I reckon you could use it to machine wood.
                                        Likewise I often notice homemade tool posts, cross slides, dividing heads and the like made from chucks of bright mild steel square bar with all the sharp corners left on, just waiting to smash knuckles and hands of the unwary. A few minutes to file a nice radius along each edge where two faces meet makes it all a lot more user-friendly. The bigger the radius, the more user friendly it is. Sharp corners always look half-done to me.
                                        Edited By Hopper on 08/03/2021 10:55:53
                                        #532534
                                        John Haine
                                          @johnhaine32865
                                          And when you say "handles", do you mean the handwheels or the bits that stick out? If the wheels, then they are pretty large diameter and you'd need a very big scissors/clamp type knurl that probably wouldn't fit the lathe! If the stick-out bits, if they already rotate, they don't need knurling.
                                          #532565
                                          Howard Lewis
                                            @howardlewis46836
                                            I have both clamp and push in types. Almost invariably the clamp type is used.
                                            This is equipped to give a diamond knurl.
                                            The push in one is for straight knurls, and is only rarely used, and then in gentle steps, out of regard for the Headstock bearings..
                                            As an Apprentice I was told to use no more than 0.010" ( 0.25 mm) depth., and have always this quite sufficient.
                                            If you overdo things when making adjusting screw, the work can shear off!
                                            #532574
                                            noel shelley
                                              @noelshelley55608
                                              my pictures11 138.jpgI bought this unit awhile ago as part of a load of coventry die headsmy pictures11 136.jpg. It is like a 3jaw chuck but with knurling jaws. Not used it yet and I'm assuming it is production gear and cost many shekels. Any comments on it's use ? Noel
                                              #532598
                                                Posted by noel shelley on 08/03/2021 13:59:46:
                                                Sorry … No
                                                But I certainly like the look of it !!
                                                Edit: Post #5 here, suggests that I might have a good eye:
                                                 https://www.practicalmachinist.com/vb/bridgeport-and-hardinge-mills-and-lathes/knurling-hlv-h-371172/
                                                Edited By Michael Gilligan on 08/03/2021 15:45:12
                                                #532620
                                                bernard towers
                                                  @bernardtowers37738
                                                  It’s a QUICK,. Used for cut knurling, just google quick knurling very interesting
                                                  #532682
                                                  Hopper
                                                    @hopper
                                                    Posted by Howard Lewis on 08/03/2021 13:35:11:
                                                    I like to have the fixed steady between the knurl and the headstock to take some of the load off the Myford's baby bearings for this reason when push knurling.
                                                    #532690
                                                    Anonymous
                                                      Graham Meek (of this parish) has a very nice design for the caliper type. I believe it's in his book but might be available separately.
                                                      Perhaps he'll chime in.
