Lathe in a Box
Lathe in a Box
Home Forums Workshop Tools and Tooling Lathe in a Box
  • #658208
    Andy_H
      @andy_h
      This 2015 thread drew my attention to the wonderfully neat "lathe in a box" Link
      The part of this solution I am particularly interested in is the belt-less method used for the motor to drive the countershaft.
      Curious if anyone has experience of using a setup like this and if so how eefective you find it.
      The photos in the above link are quite small and not too clear when zoomed but….
      It looks like a plywood ring has been screwed to the outer surface of the original drive pulley. That seems very easy to fabricate but I reckon it needs to be truly concentric to the pulley and with a even internal surface to avoid inducing annoying vibration.
      I'm less clear on the motor drive side of this setup. Looks like a rubber wrapped brass boss attached to the motor shaft – a bit like a over-sized version of pinch roller found in cassette players! Any suggestions on how to make this (assuming such a component is not available?) or, more to the point, what to use?
      Andy
      Andy_H
        @andy_h
        #658214
        DC31k
          @dc31k
          Posted by Andy_H on 27/08/2023 14:13:08:
          Looks like a rubber wrapped brass boss attached to the motor shaft – a bit like a over-sized version of pinch roller found in cassette players! Any suggestions on how to make this…
          Make the motor 'pulley' first. Any old bit of hardwood would do. Drill and tap so it can be secured to the motor shaft. Shape roughly circular with hand tools. Mount on motor. Switch on. Apply sandpaper glued to a flat board until the pulley is round and smooth.
          Glue sandpaper, rough side out to finished pulley. Switch on and apply to rough finished plywood disk on countershaft. Rotate countershaft slowly. Once plywood is finished round, concentric and smooth, remove sandpaper from motor pulley and replace with rubber.
          A smart person would size the motor pulley so something like a slice of mountain bike inner tube fits it snugly.
          #658321
          Andy_H
            @andy_h
            Posted by DC31k on 27/08/2023 15:17:50:
            Thanks for the suggestion. My badly worded question was aimed at the rubber covering on the motor disc. The inner tube slice is an interesting idea but I'm wondering if that would be think enough and robust enough. But the idea has led me to look at large bore reinforced rubber hose.
            Also, for the wooden boss on the motor shaft I'm thinking of boring that out and gluing a couple of shaft collars into the hole. Thinking this may be a more secure (safe) way of fixing to the shaft rather than relying on a screw through the wood – which could result in the wood splitting when under load?
            As for the countershaft side of things. I am now thinking of using two rings bolted together with the pulley sandwiched between them. This would avoid ruining the original pulley buy drilling holes through the rim.
            Main hesitation still is whether the whole setup would be effective so would still be interested to hear if anyone has used this method
            Andy
            #658330
            peak4
              @peak4
              I've not tried that, but assuming finances allow, how about an internally toothed gear such as these, along with the appropriate spur gear(s) on the motor.
              https://www.hpcgears.com/n/products/6.internal_gears/internal_gears.php
              Bill
              Edited By peak4 on 28/08/2023 20:31:41
              #658365
              An Other
                @another21905
                I don't know if they are still obtainable, but would a hard rubber doorstop be suitable for the drive pulley? – I,m thinking of the slightly conical things about 3cm high x 3cm diameter.
                #658387
                Andy_H
                  @andy_h
                  Posted by An Other on 29/08/2023 09:15:08:
                  That's a good idea.
                  Looks like this may be perfect as it's 50mm diameter, and also straight sided rather than conical. I'd have to remove some material from the centre to fir the boss on the shaft.
                  I'm guessing rubber is not very machinable (more of a hole-saw job) – or am I wrong?
                  Andy
                  #658389
                  Grindstone Cowboy
                    @grindstonecowboy
                    Popping it in the freezer for a day might help stiffen it up enough to be more easy to machine. Of course, you're then fighting the fact that it's warming up as you go, so work fast
                    Rob
                    #658403
                      I would probably look at skateboard wheels … some of them are modestly priced, and it would be easier to machine a new core than to machine rubber.
                      No connection with these people [they probably wouldn’t have me] … but here is an indicative range:
                      https://www.skatehut.co.uk/skateboards/skateboard-wheels?productListFilters=&productListPgNo=1
                      Edited By Michael Gilligan on 29/08/2023 17:47:37
                      #658783
                      Andy_H
                        @andy_h
                        Posted by Michael Gilligan on 29/08/2023 17:43:40:
                        That looked like an interesting suggestion but having looked into more detail it seems these are all made of plastic materials and I am thinking this would not provide the required degree of friction for driving the countershaft wheel.
                        My current idea is to use one of the larger and "chunkier" Rubber ferrules for a walking stick which has a solid parallel sided Rubber section on the end. Unfortunately the diameter of that section is 15mm less than I really wanted but can compensate for that by adjusting the diameter of the countershaft wheel.
                        Andy
                        #658785
                          You might want to look a little deeper, Andy: **LINK**
                          https://www.slamcity.com/pages/hard-skateboard-wheels-vs-soft-skateboard-wheels
                          … or maybe not
                          Andy_H
                            @andy_h
                            Posted by Michael Gilligan on 01/09/2023 21:19:41:
                            … or maybe not
                            I take that back! Thanks, that link gives a good explanation of the hardness numbers that had previously mystified me.
                            Andy
                            #658886
                              You’re welcome, Andy
                              I shall be very interested to see how you get on, if you decide to use them.
