Lathe identyfication help
Home Forums General Questions Lathe identyfication help
  • #641968
    Daniel Piotr
      @danielpiotr98376
      Hello
      I come from Poland. I have an opportunity to purchase probably a Myford lathe -That's what the seller says but I have my doubts about it. Unfortunately, the nameplates are missing on the lathe. Please help me identify the manufacturer and model (I am sending pictures). I am also interested in documentation or advertising catalog where I can find it.
      https://ibb.co/23MVZdp
      https://ibb.co/C6QyfS9
      Thank you sincerely
      Daniel
      Daniel Piotr
        @danielpiotr98376
        #641971
          It may [at the right price] be worth buying … BUT, it looks like no Myford that I have ever seen.
          Clive Foster
            @clivefoster55965
            Daniel
            Home or, more likely, workshop made lathe. Parts carved from solid so builder had access to reasonably substantial machines but, judging by the tailstock, apparently no welding facilities.
            In many ways it looks to be a very decent job but the topside and tailstock look weak. Topside dovetail rails are screwed on. An effective old school way of making such when dovetail cutters or shaper aren't available. Fundamentally soundly engineered but the top plate looks very thin. Tailstock looks to be built up using angle for the main body which is weak without welded on bracings.
            #641985
            Jelly
              @jelly
              I agree with Clive, it's definitely a workshop made machine.
              It looks like it's been built using some components from a Myford "Euro-Ten", which might be how the Myford name got attached to it, but it's easily ¾ home built parts.
              If it's a reasonable price and will get you going now I wouldn't turn it down just because it's home built, but don't pay top dollar top euro for it.
              It looks to have an eccentric (in both sense of the words) mechanism to provide screw cutting feeds, which you would likely need to work out for yourself as I've never seen anything like it; or replace it with a banjo for change gears.
