Lathe Drive Systems and Belts
Home Forums Workshop Tools and Tooling Lathe Drive Systems and Belts
Viewing 2 posts - 26 through 27 (of 27 total)
  • #656713
    James Alford
      @jamesalford67616
      Andy_H.
      Yrs. The jockey wheel is about four cheap roller bearings on a long bolt, bolted onto a length of flat steel bar. The other end is screw to the block of wood that supports the counter shaft. It is all looks very crude, but it is effective. The belt firm the motor to the counter shaft is simply taut and has no tensioner. It never slips.
      James.
      Andy_H
        @andy_h
        Posted by Adrian R2 on 10/08/2023 16:23:47:
        I tried out a recycled cordless drill motor which worked OK but I didn't like the aesthetics of it.
        Out of interest what did you use as a power source in that setup?
        Andy
