Hello again gentlemen, me again!
I need to use a 19mm ball end cutter to cut a half sphere into a piece of 25mm brass. However, now looking at the drill chuck on dad's lathe, it only takes a 13mm shank – the shank on the ball cutter is 20mm.
So, do I buy another chuck for a one off use? Or is there another way? Is there an adapter (I doubt it but might be worth asking) that would fit into the 13mm chuck and accept a 20mm shank?
Another option, could I turn part of the piece of 25mm brass bar stock I have down to 13mm and mount that in the drill chuck, then mount the ball cutter in the lathe chuck – would that work or could you see disaster looming on the horizon?
If I need to buy another chuck – how can I tell what taper – 2MT or 3MT etc the lathe takes? All I know is, it is a (Chinese I think?) lathe from Harry UK about 12 years ago.
Thanks in advance…. again!
Margaret
