Lathe chuck not true.
Home Forums Help and Assistance! (Offered or Wanted) Lathe chuck not true.
Viewing 25 posts - 1 through 25 (of 30 total)
  • #343996
    Stephen Follows
      @stephenfollows82099
      My Myford ML7 spindle runs true but when I have a three jaw chuck fitted the workpiece runs out by around 3 – 4 thou. When I work the piece it always comes out true but it does mean starting oversize and cutting back. For a 1" finished product this usually means starting at 1 1/4" and so on for other sizes. A wasteful practice. Can I correct the chuck or is it a case of a new chuck? Maybe this is just how it is and I have to live with it. Comments appreciated.
      Stephen Follows
        #343997
        Ian Parkin
          @ianparkin39383
          Hold a die grinder in the toolpost and with the jaws opened and locked in position with a fixture take a gentle pass off the inside of the jaws (whilst lathe is stationery)
          this may only hold true for thgis diameter depends on the quality of your chuck/scroll gears etc
          Edited By Ian Parkin on 02/03/2018 14:03:41
          #344001
          Mick Henshall
            @mickhenshall99321
            First make sure chuck backplate threads and spindle register are clean a bit of swarf can throw the chuck out, also scroll and the jaws should all be clean, people do regrind the jaws with a toolpost grinder to true them up, personally I nearly always use a 4 jaw independant chuck and dial in the work to run true
            Mick
            #344002
            Stephen Follows
              I have both independent and self centring 4 jaws. The self centring is good but doesn't hold small work as well as the three. Probably have to get used to using the independent more often!
              #344003
              Brian Wood
                @brianwood45127
                Hello Stephen,
                Before you get into grinding the chuck jaws there are a number of other things to check which may be all that is needed.
                First of all, is this a new chuck to you? Has it been fitted correctly on it's backplate? I would first use a soft faced dead blow mallet or stout block of wood to tap the chuck in the direction needed to reduce the error you report. It could well move very slightly on it's location to put matters right.
                3 or 4 thou error is not bad really, certainly for reclamping a job in the jaws since it could well settle slightly differently every time you do it. Run round the chuck with the chuck key and tweak all the key points to get an even loading on the scroll.
                Grinding jaws will not correct that sort of error without giving them a true rim to grip on to start with and it is a rather desperate method of correction
                #344004
                Jon Gibbs
                  @jongibbs59756
                  Hi Stephen,
                  I have an ML7 and suffer the same problem with my old 3-jaw but decided to make my backplate adjustable – think 4-jaw sub-backplate, to tweak my 3-jaw to work with minimum run-out for certain diameters.
                  Mine is TIR minimized for 1" diameter stock because I also have an ER32 collet chuck but can adjust it if needed fairly easily.
                  I hope this helps
                  Jon
                  #344012
                    You will be lucky to get better than 0.001" even with a new chuck unless it is a good one AND scrupulously clean* – you only need one bit of swarf on the scroll to introduce such an error.
                    If you can make your OD 25mm it should come out of 1" stock with even a worn chuck.
                    *I have two 4" SC chucks (one Indian one Chinese) that can do 0.001" but it takes cleaning to achieve this. An in-situ clean is enough, but it MUST be done.
                    #344018
                    not done it yet
                      @notdoneityet
                      Are the jaws and chuck numbered? Changing the positions of the jaws can alter the runout. Even changing the position the chuck is fixed to its backplate (if that type) will likely alter things slightly – particularly if the spigot was not quite true and well fitted. There should be fitting marks, for the original orientation, if it is separate backplate and chuck.
                      Other things to look for are a backplate that has not been undercut at the internal spigot angle or (unlikely) the spigot is too long.
                      Do every check possible before resorting to grinding the jaws. smiley
                      Edited to add:  Why not start with 27mm, or whatever, rather than 1 1/4” for a 1” finished size?
                      Edited By not done it yet on 02/03/2018 16:13:38
                      #344020
                      John Haine
                        @johnhaine32865
                        4 thou ain't bad.
                        #344021
                        Stuart Bridger
                          @stuartbridger82290
                          Agreed, 4 thou ain't bad. It's about the best I can get with an admittedly old 3 jaw PB chuck. If I need better its either a 4 jaw or collet.
                          #344046
                          Pete Rimmer
                            @peterimmer30576
                            Grinding the jaws should only be a last resort IMHO and only after careful checks have been made. If you think about it, jaws are hardened steel and a very compact and strong shape. Chuck face is essentially a flat disc of cast iron with three slots milled in it. If something's going to go out of shape when abused it's more likely to be the soft iron chuck not the hard steel jaws.
                            I had a 4 5" PB chuck with severe runout that varied between 8-15 thou and I suspected the jaws until I put them into another similar PB chuck and they were perfectly fine. Turns out the slots in the front face of the chuck were dished and it was holding the jaws bell-mouthed, probably from being abused by over-clamping something held at the extremities of the jaws.
                            Consider also the commonly accepted statement that grinding the jaws is only good for the diameter they are ground at. That is exactly what you would expect if the chucks jaw guides were dished or domed.
                            Edited By Pete Rimmer on 02/03/2018 18:24:30
                            Edited By Pete Rimmer on 02/03/2018 18:25:01
                            #344061
                            Redsetter
                              @redsetter
                              Stephen,
                              It is normal practice to assume a 3 jaw will not run true, and to start oversize then turn down to diameter. If you have to get a piece to run true you use a 4 jaw independent chuck, or a collet. If you really must do it in a 3 jaw, you can shim one of the jaws. It is what I and many others have done for the past 50 years. Don't worry about it!
                              #344062
                              roy entwistle
                                @royentwistle24699
                                Personally I would never consider a 4jaw self centreing chuck for engineering. Woodwork possibly. The main reason being that many is the time I've found that metal isn't square
                                Roy
                                #344067
                                Billy Bean
                                  @billybean67480
                                  I bought a unimat to learn on and soon found out the 3 jaw did not run true.
                                  I bought a new unused 4 jaw independent on ebay and that is all I use now for round and square.
                                  Takes a bit longer to set up with a DTI but suits me for my little bits.
                                  Not sure if this is what the experienced members of the forum would do ?
                                  #344077
                                    Posted by roy entwistle on 02/03/2018 19:37:05:
                                    Roy
                                    4-jaw SC holds round work very well.
                                    roy entwistle
                                      @royentwistle24699
                                      Neil It does if the bar is round. I've come across a few that had three lobes, particularly on ground stock
                                      Roy
                                      Edited By roy entwistle on 03/03/2018 11:26:35
                                      #347111
                                      Martin of Wick
                                        @martinofwick
                                        That old chuck problem again.
                                        Generally, I thought I wasn't bothered by chuck run-out as usually try to avoid second chucking and I was using a Burnerd and they are good so we are told, so wasn't expecting significant run-out.
                                        On having some issues, I actually checked with a DTI and was shocked to find a 10 thou total run-out (on both sets of jaws vs. less than 1 thou run-out on the outside of the chuck body (using silver steel test pieces).
                                        So strip down, clean, inspect, relube and reassemble. There was no damage or obvious wear steps in the scroll, jaws or chuck body. In fact the jaws were in remarkable condition, no trace of bell-mouth or jaw damage evident.
                                        On reassembly, slight improvement was noted to 9 thou TIR on both sets of jaws, slightly less for smaller diameters of silver steel (1/4, 1/2 and 5/8 was all I have to test).
                                        The chuck is a Myford having a backplate with threads inside the chuck body and actually quite a tight fit, so wasn't expecting to gain much by rotating the chuck body with respect to the threaded back part. In fact this did help and gave a slight improvement reducing TIR to between 5 and 6 thou.
                                        Experiments with shimming the apparently low side jaw with strips of paper showed that TIR could be reduced further (between 0 to 2 thou (which would be acceptable).
                                        Assuming the chuck was good once, how can a scroll or jaws selectively wear to end up like this?
                                        and should I now resort to grinding? to be achieved by carefully skimming off some material from the two apparently high jaws (say half thou at a time in the tool cutter grinder, replace, check, repeat until TIR is within reason etc). Or just shell out for a new chuck?
                                        By comparison, the Chinese chuck on my Seig C1 is still within 2 thou TIR after years of abuse. No idea how old the Myford chuck is, the machine is mid 70s and has not had hard use. It is possible the chuck is the original but may not be.
                                        Would appreciate any thoughts on whether there is anything else I can try before the dreaded grinding option. Don't want to grind in situ from the tool post either!
                                        #347123
                                        Brian Wood
                                          @brianwood45127
                                          Hello Martin,
                                          Try testing the vertical register in particular on the chuck backplate, you may well be surprised at what you find!
                                          Skim that if necessary and that could well be an end to your trouble.
                                          #347125
                                          Martin of Wick
                                            @martinofwick
                                            Brian,
                                            thanks for that.
                                            I think I understand, but just to be sure, are you saying remove the chuck body from the internally threaded back plate and then check the fore and aft run-out on the outer mating surface of the back plate to test if that surface is truly normal to the spindle axis?
                                            That hadn't occurred to me as a source of error.
                                            #347128
                                            Brian Wood
                                              @brianwood45127
                                              Hello Martin,
                                              Yes, that is exactly what I meant. It will be interesting to hear what you find. A tiny degree of runout there will have a disproportionately large effect when you reach the chuck jaws.
                                              I hardly need to say it but do make very sure that the fitting of the backplate on the lathe spindle is scrupulously clean otherwise you will begin to chase the wrong thing!
                                              And before you separate chuck from backplate, centre pop the joint on either side so that it goes back in the same orientation as before.
                                              #347129
                                              Martin of Wick
                                                @martinofwick
                                                Brian,
                                                Thanks, I will check that later tonight and report!
                                                Martin
                                                #347141
                                                Andrew Tinsley
                                                  @andrewtinsley63637
                                                  Three thou run out on a 3 jaw isn't bad! I cannot emphasize enough that the chuck and spindle nose should be ABSOLUTELY clean. In my early days at using a lathe, I was plagued by variable run out of anything up to 10 thou! Cleaning both the chuck thread, scroll and the spindle nose made the run out about a consistent thou.
                                                  If you genuinely have a 3 thou run out, then you can always convert the back plate to a "sort" of Burnerd Grip Tru chuck. I think Commander Barker was the first to describe the mod and then GHT wrote it up. You can buy a kit from Hemingway to convert your chuck, but best read GHT's manual of workshop practice, it is described therein.
                                                  Grinding jaws is a last desperate resort for a worn out chuck as far as I am concerned and then it only works for one diameter.
                                                  Andrew.
                                                  #347151
                                                  Martin of Wick
                                                    @martinofwick
                                                    Brian,
                                                    You Da MAN! !!!
                                                    The back plate of the integral Myford chuck comprises the register only as the threaded portion is in the chuck body. However, that register portion was a good fit on the mandrel nose and not going to wobble from the pressure of a DTI.
                                                    Even so I checked several times in differing positions and the result was always the same – 3 to 4 thou run-out in the plane normal to the spindle axis. Moreover, the low and high positions corresponded to the low and high chuck jaw run-outs, so well spotted.
                                                    I can see how this part not being truly normal causes the problem, but cant understand how it ended up in that condition – or was it like that from day 1?
                                                    Next thing to do is make up a slim tube/top hat 11/4"W12 nut arrangement to secure the register plate tightly to the mandrel for skimming – that will be an interesting internal threading project! If my dodgy geometry is correct skimming the chuck back register should eliminate 80 to 90% of the chuck run-out at the jaw location.
                                                    It is great to know what the real cause of the problem was and you have saved me committing the unspeakable crime of jaw grinding!
                                                    So thanks very much Brian!
                                                    Martin
                                                    #347190
                                                    larry Phelan
                                                      @larryphelan54019
                                                      Talking about round stock being "out of round",we get that quite a lot over here. We just deal with it and get on with the job.
