An Allen key is made of exactly the right material .
Very cheap to buy . Just grind a square on the end and use as is or insert a section into a mild steel T handle .
Grind square on shortleg to use as is and on the long leg to cut off for insertion into handle .
Old Allen keys make all sorts of useful tools :
Other Allen keys of odd sizes by grinding smaller .
Square head keys .
Screw drivers – especially for restricted access .
Drivers for odd screw heads .
Easy outs – grind a square or hex taper and ram into hole .
MikeW
