Posted by Robert Atkinson 2 on 08/11/2019 12:45:05:
Posted by ChrisH on 07/11/2019 00:05:13:
<BIG SNIP>
Remember also, whether in your own shed on your own or in the firms shop, an accident only ever happens due to there being an unsafe action taken or unsafe condition existing. It therefore the responsibility of all of us to ensure unsafe conditions do not occur, neither do we take unsafe actions, however we operate our machines or provide for our own safety.
Have a nice day!
Chris
The problem is that you say you have taken that first "Unsafe action" – removing the guard- in your workshop. You also seem to be advocating removing guards to others.
Sorry Robert, but you are wrong in your criticism of me in both respects.
Regarding your "Unsafe Action", the guard was removed so that a potentially "Unsafe Condition" could be addressed. You seem not to have appreciated the significance of what was written in the whole paragraph. I said the guard interferred too much with the setting up process. This it did. If the job to be milled is not very well secured to the mill table then the likelihood exists that it can move when being machined. This could result at best with a damaged part and broken cutter; at worst the part could be flung off the table and cause the operator serious or possibley fatal injury. I like to try to avoid such situations arising so if the guard got in the way of me applying clamps etc and bolting it all down, being able to get the spanner on the nuts, then it is right in my mind to remove it. Better the job is securely fixed down. The last sentence in that paragraph said that I fitted a temporary – meaning not permanent thus removable – screen (guard) to stop swarf and coolant being flung out. I should have said that this is the length of the table giving a better length of protection; I could have also said that if it stops swarf and coolant being flung out it also stops me trying to put my hand in to the cutter area too, but I sort of assumed that folk reading that would figure that for themselves. So I removed a badly designed guard and replaced it with a better one, hardly an Unsafe Action.
No-where in my post did I advocate removing guards to others, so where you deduced that from is a mystery. Look, if someone wants to remove all the guards from their machine, or in reverse, totally enclose their machine with guards, then that is up to them. It is their machine, their shed, their responsibility; I would not presume to advocate any action to them, it's nothing to do with me, but having worked as a H&S advisor I would not advocate removing guards to others, unless, as in my case above, it is to be replaced with better guarding.
What I did try to do in my post was make the point that a) too often guarding fitted to machines is badly designed in that it prevents the operator in running the machine efficiently, or sometimes not at all as has been alluded to in other posts in this thread, or the maintainence engineer easily accessing the parts to be maintained, and b) guarding should be designed and fitted once the designer has seen for him or herself how the operator and engineer have to go about their respective tasks. A well guarded machine is usually a joy to operate in comparison to a badly guarded machine, and the bonus to the production manager is not only does he/she know it is a well guarded machine for their operators but production line efficiency usually rises as a result of it too.
Having been involved in the application of guarding to numerous machines, some built in a time before modern standards were required and thus were never designed to be guarded, I know only too well the issues involved. I also know, having seen first hand examples, the lengths some operators will go to circumvent badly designed guarding, human nature being what it is, leaving the machine in an Unsafe Condition.
Chris
