That sounds like a well equipped machine.
Re change gears, do you have the gear train between the spindle and the gearbox? For an imperial "A" machine this should be four gears thus:- 20t; 80t idler; 56t and with a 40t, normally mounted as a spacer, to replace the 20t for the coarsest pitches, ie 4 to 7 tpi.
There is normally no need for other gears unless you require metric piches..
Edited By Clive Brown 1 on 22/01/2022 21:28:22
