Well I always use a handle for all die threading – better feel, and quicker too.
Smaller lathes often go to these very slow speeds simply because they don’t have the torque available to cut a really deep thread without. Things like Acmes, and the like.
OK , are you going to cut any deepish threads – possibly not, but then again, if you need to, its because you really need to!
Knurling likes a good slow speed.
I’d suggest 60rpm being as fast as one would wish to go in that dept, if oyu haven’t, as most of us havent, single point instant release clutches. (And a good flip out retracting toolholder might be high on the manufacturing list!)
How to get there. Well jack shafts and all can work, but its all getting a bit complex?
If it were me, I’d cheerfully trade a geared head, for a belt drive, backgear and Norton box, if that gave me a good range of speeds and feeds.
Formulae – yes quite easy. Compare diameters. D1/D2 will give the output RPM and torque increase.
ie you have an input speed off the motor of say 1425rpm. You want to get down to 200rpm. At the mandrel 1425/200 = 7.125 So the the total ratio, using the jackshafts needs to ensure that the final drive is 7.125 x bigger than the motor pulley (effective diameter.) You can get there in one step, or 2 steps, or 10 steps, as long as it all tots up to 7.125.
And 7.125 will be the torque multiplication. Mathematically its not complex, but Id suggest, if you want to do that, you get a short book on gears and gear trains, which will cover the principles and then you’ll be right first time with relatively little trouble.
If you can though, just buy the right lathe – you are going to have it for a long time! (I hope)
Edited By meyrick griffith-jones on 19/10/2009 18:19:44
