Lathe 3-jaw chuck
Lathe 3-jaw chuck
Home Forums General Questions Lathe 3-jaw chuck
  • This topic has 9 replies, 7 voices, and was last updated 5 May 2020 at 07:42 by Bootlegger Blacky.
  • #469031
    Bootlegger Blacky
      @bootleggerblacky
      924abf00-4463-4699-9f5d-e9f0da812238.jpeghello, I have a very nice 3-jaw chuck 100mm.make unknown.. But only have the outside jaws and I am finding it impossible to locate a set of inside jaws..any ideas?
      Bootlegger Blacky
        @bootleggerblacky
        Inside jaws info
        #469038
        Brian Baker 2
          @brianbaker2
          Greetings, buy a set of soft jaws to suit your chuck, and use those.
          regards
          BB
          Edited By Brian Baker 1 on 04/05/2020 12:41:16
          #469047
          Bob Stevenson
            @bobstevenson13909
            Well it's NOT the ubiquitous Sanou/Feurda 'K12' 100mm because I've just put my vernier on a jaw and the dimensions are different…..However;….. A set of jaws is likely to be quite expensive whereas the said K12 is an inexpensive chuck…due to the hated jaw changing ceremony I'm currently thinking about buying another chuck so that I can just change the chuck on the lathe…. Curent price for K12 (which apart from jaw changing is quite a nice chuck) is about £46 from Arc.
            I can change the jaws on my Colchester lathe in a few moments but for some reason the little K12 jaws are a bugger!
            What lathe are you using this on?
            Edited By Bob Stevenson on 04/05/2020 13:14:36
            #469054
            Tony Pratt 1
              @tonypratt1
              Try 'Thame workholding' **LINK**
              Tony
              #469055
              Martin Kyte
                @martinkyte99762
                The above link may help you in your search. Rotagrip do lots of chuck jaws including soft jaws.
                regards Martin
                #469087
                AdrianR
                  @adrianr18614
                  If you fancy a challenge Howard Hall has a page about making Soft Jaws It nicely explains how to cut the teeth.
                  Knowing how to measure the scroll and teeth could be useful for identifying ready made jaws too.
                  Adrian
                  #469135
                  old mart
                    @oldmart
                    In this Rotagrip listing there are some of the dimensions of the soft jaws they sell. Just scroll down until you see the lists.
                    old mart
                      @oldmart
                      I think that the Polish Toolmex and Bison 100mm chucks look to be front runners. The EN10 soft jaws have a 6mm scroll pitch and a 6mm slot width. There are so many variations in the size of chuck jaws that it really is a lottery as to whether you can get what you want.
                      This ebay listing has a chart giving more detailed sizes for the Polish hard jaws:
                      https://www.ebay.co.uk/itm/lathe-chuck-scroll-type-hard-inside-jaws-to-suit-HDC-Toolmex-Bison/281753185414?hash=item4199cc6c86:m:mmpnrvSLNSVXsFrAn9jxRrA
                      Edited By old mart on 04/05/2020 21:03:41
                      #469221
                      Bootlegger Blacky
                        @bootleggerblacky
                        Such a wealth of information,thank you to all,it’s looking very much like a…EN10. Also as a novice,I have now learnt what soft jaws are! All of your feedback is much appreciated.Regards.
