A small note for anyone wanting more grunt for whatever reason
It apparently depends upon the voltage, so 24V if you're on a hobby setup, 48V for more power and 72V if you're a real man
The Mach3 guys have lots of threads on stepper voltage
Nema 17 at the bottom, Nema 23 in the middle and 34 is the biggie
However there are more alternatives, AC servo motors and other kit that industrial level guys use, it's actually a pretty huge and diverse industry and you need to check that the route you take has the software as well as the hardware to do the job you want if you take a different path
Edited By Ady1 on 10/09/2023 09:14:29
