I have one of those laser edge finders, and am still not convinced as to how accurate it is.
I also have a Haimer 3D taster which is absolutely superb but too bulky and awkward to use on a regular basis.
And I am always worrying that I might drop it or something.
On my Alexander Miller and the Boley (BCA) jig borer I use these most of the time.
The one on the right is my 'everyday' edge finder and is no more than a 1/2" OD ball race loctited to the end of the collet adapter for the Boley, the one I use on the Alexander is even simpler and is just a plain bar with a bearing on the end which is then held in the machine collet.
In use you simply run the job gently up to the bearing with the spindle running, and when the outer race stops spinning you know you have just touched the job with it. Then use the DRO in the usual way taking into account the 1/4" radius of the bearing.
It is such a simple tool to make and use, to the point I rarely need anything else for most jobs these days.
Phil
Edited By Phil P on 27/02/2015 14:52:26
Edited By Phil P on 27/02/2015 14:57:35
