An alternative to laser cutting is water jet cutting which does not have the problem caused by heating the metal.
Materials are cut using a jet of pressurised water as high as 60,000 pounds per square inch (psi).
To increase cutting ability, abrasives such as garnets and aluminum oxide are often added. The overall process mimics erosion in nature, just at a much higher speed and concentration. Water jets are capable of cutting many industrial materials including stainless steel, titanium, aluminium, tool steel, ceramics, granite, and armour plate.
Paul
