Posted by Michael Gilligan on 13/11/2014 08:11:10:
Posted by Chris Trice on 13/11/2014 02:47:11:
You can't beat a sticky pin.
Chris,
Forgive my ignorance but; how would you use a sticky pin to align the centre of an existing large diameter hole?
I know how to use one to locate a tiny centre-pop, or an edge, but that's a different matter.
Same way as an edge, pick one side of bore with the sticky pin, zero dial or DRO. Move X axis to other side of bore, pick bore edge as before. Use the feed dial to move the table to a position half way between1st & 2nd reading this will be centre in X direction, repeat for Y direction.
Its best to operate roughly in the bore centre to start with, a sticky pin isn't the most accurate way to do this process. Using a true running dowel & touch the bore in 4 places is better and then the best is using a DTI to centralise the spindle to the bore is the most accurate.
Tony
