Large diameter copper tube
Home Forums Materials Large diameter copper tube
Viewing 15 posts - 1 through 15 (of 15 total)
  • #311477
    Roger Clark
      @rogerclark
      Does anyone know of the best price for 7.25" copper tube about 30" long and would 1/8" be strong enough for a loco boiler?
      Roger Clark
        @rogerclark
        #311480
        Dave Halford
          @davehalford22513
          try Blackgates, but 71/4" pipe may not exist which may leave you with design issues.
          Fizzy on here makes boilers
          #311486
          Thor 🇳🇴
            @thor
            M-Machine lists 7" C106 tube in their metals catalogue, have you asked them for a price?
            Thor
            Edited By Thor on 11/08/2017 13:47:31
            #311498
            Roger Clark
              @rogerclark
              Posted by Thor on 11/08/2017 13:44:42:
              Thor
              Thanks Thor, query sent.
              #311547
              D.A.Godley
                @d-a-godley
                Try P&P Non-Ferrous Metals tel 01384 868080 . They a have a large range of tube and I found their prices quite reasonable .
                I have no connection other than being a satisfied customer .
                #311548
                duncan webster 1
                  @duncanwebster1
                  7.25" * 10 swg should be OK at 100 psi, but discuss with your club boiler inspector before committing a large amount of money. If you intend to operate in public you will need insurance, and the best way is to join a ME club and use their's. Sounds like this isn't a standard design or you wouldn't be asking the question.
                  #311556
                  nigel jones 5
                    @nigeljones5
                    pressure no problem but I dont know of anyone who sells this size …might need it rolled
                    #311557
                    nigel jones 5
                      @nigeljones5
                      blackgates stock 6" then 8 1/4"
                      #311567
                      Brian John
                        @brianjohn93961
                        What is large diameter copper pipe of that size usually used for ?
                        #311571
                          Posted by Brian John on 12/08/2017 05:53:51:
                          There is a clue in the question:
                          It is just a larger version of the copper tube you use for your models Brian.
                          #311577
                          Mike Poole
                            @mikepoole82104
                            I am sure it is not manufactured to satisfy the demand from the model market, it must have uses in the industrial and scientific equipment market but I can't say I have seen it used.
                            #311602
                            Ian S C
                              @iansc
                              7.25" isn't available here, the size goes from 6" to 8", and then 10" 12". There seems to be nothing in NZ that is near 7", and I think the range of sizes held by my local supplier would be fairly international, so you may need to roll your own.
                              Ian S C
                              #311607
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi, I have a short piece of 4" copper pipe that came from a canning factory, which no longer exists, which I believe carried water for food processing. I dare say that larger sizes were also used and I suspect many food factories had large copper pipes at one time, and maybe even Whisky producers would use such sizes.
                                Regards Nick.
                                #311612
                                Ian S C
                                  @iansc
                                  Been having a look around, and you may find 180 mm dia copper tube, the place I looked had a minimum order of 500kg, but someone must have 30 inches of it.
                                  Ian S C
                                Home Forums Materials Topics
