Posted by mick H on 28/12/2011 15:43:36:
Skarven….when I tried out vegetable oil…cannnot remember which type…. as a lubricant, it tended to form a skin when it dried out which I found difficult to remove and involved a strip down of topslide etc Do you find any problems of this sort with rapeseed oil?
Mick
I haven’t seen any tendency to dry out or leave a residue at all. It seems to behave as a common motor oil. I have used it now for a few months, and have had no problems so far.
It is easy to remove from your hands with paper towel and acts more like ‘hand lotion’
I think the viscosity was somewhere between ISO32 and ISO46 hydraulic oil.
The fact that it was used as lubricating oil for steam engines should mean that it has some good qualities.
Castor oil (that is the US term, isn’t it) will leave a residue which can be difficult to remove, but I do not know if they are comparable. From Wikipedia: ‘However, castor oil tends to form gums in a short time, and its use is therefore restricted to engines that are regularly rebuilt, such as race engines.’
I will report back if I find any problems with the .
So far my problem with cutting oil is the mess, and the fact that tiny Aluminum chips are so light that they make the oil into a grey soup. They don’t fall to the bottom of the tank like the steel chips, and they can’t be removed with a magnet. I think I will make some kind of system with a circulation pump and a filter. Of course, this problem is probably not because of the rapeseed oil, but it could be caused by the relatively high viscosity.
