Just my pennyworth,
That is a serious machine, I,m surprised it has only a 1 hp motor.
As others have said, it might be worth checking to see how the motor is wired, and also check if the converter is strong enough. I had a somewhat similar problem some years ago, using a borrowed static converter to run my planer, the machine just laughed at it.
Turned out that the converter was just too small, so I ended up buying a rotary one, problem solved ! The last thing you want is to burn out your starter, so do a check on the motor AND the starter coil, then look at the converter.
Let us know what you find, all info comes in useful.
