KX1 CNC Mill Clearance Offer
Viewing 25 posts - 26 through 50 (of 155 total)
  • #397166
    Ron Laden
      @ronladen17547
      I think Ketan mentioned damage Jason is it just cosmetic or the workings of it.
      Emgee
        @emgee
        Jason, that machine will slow your building projects down a bit while you get to grips with cnc !!!!!
        Emgee
        #397174
          Ron A quick look in the back does not show anything obvious and the need moves when I manually turn the ballscrew so will probably have to power it up to see what may be the problem. As it is something on the Z-axis I won't lift it onto the bench until that is sorted as it is far easier to get to while on the pallet.
          Emgee, just think how fast I might be with that running while I'm making other parts on the lathe or manual mill at the same timefrown
          #397184
          Thor 🇳🇴
            @thor
            Congratulations with your new toy Jason, I guess you will keep us posted on your CNS progress.
            Thor
            #397186
            Another JohnS
              @anotherjohns
              Andrew;
              For quite a while I worked at a research site that had a machine shop about the size of a football pitch.
              2 friends worked there. One of them left years ago, then a year or two ago I left.
              Anyway, friend #1 – "what do you have a manual mill for? All ours are CNC. You want to make one-offs – come over here and I'll show you conversational programming" (my eyes went wide open!)
              Friend #2, has a shop @home, 2 CNC mills, zero manual mills. "why would anyone have a manual mill??"
              These guys are machinists by profession (doing precision research projects, not metal bashing), and I'm not. So when these well trained guys ask a question and show me how a pro does it… I'm all ears.
              #397188
              Another JohnS
                @anotherjohns
                Jason;
                With regards to having 2 machinists (one a CNC robot);
                I've found that I can't concentrate on doing complex stuff when my CNC is running. Cleaning the shop, doing the washing up in the kitchen; that kind of stuff I can do.
                I've always got an ear open listening to the CNC for "strange sounds" like material coming loose, cutter dulling, etc.
                I don't know why; the little KX1 (running LinuxCNC) runs for hours and hours without issues. I'd presume that Mach3 would have the same reliability, but no experience with that SW so can't comment.
                Maybe it's just me being paranoid. I'd (honestly) like to hear on how others do with leaving the CNC mill running, while going and doing something else complex.
                Note that I did have ONE problem with the KX1. Actually, my software and hardware; I had set up the software (hand-tuned by me – yeah right! bad idea!) so that pulses to the stepper controllers were right at the limits according to the spec sheets, and one of the stepper controllers missed a pulse (about 1 in a million) when stepping one direction. Backing off the minimal numbers solved the problem. Lesson – never trust the minimum numbers on spec sheets!
                #397189
                Ian Johnson 1
                  @ianjohnson1
                  Posted by Andrew Johnston on 20/02/2019 13:07:34:
                  Posted by Ian Johnson 1 on 19/02/2019 14:07:58:
                  Oh I got my 4th axis yesterday! I can do a lot of damage with another axis! Does anyone know how to work these things? laugh
                  Sort of! There are two basic modes of operation. One, using the 4th axis as an indexer, ie, the table makes a rotation and then a cut in X, Y and Z, followed by another (none cutting) rotation and so on. Like this setup for machining a bevel pinion:
                  After Final Cut
                  Two, continuous where the 4th axis rotates at the same time as, and in sync with, movements in X, Y & Z. Like this setup for machining a worm:
                  As ever the problem is creating the code. The bevel pinion G-code was generated by CAM, the worm G-code was hand written.
                  My CNC mill doesn't have hand wheels so I can't use it in manual mode. I've played with the MDI interface, but if the cut is simple enough to do with MDI then it's going to be a darn sight quicker to do it on the manual mill. I prefer to keep the manual and CNC mills separate. Part of the planning for machining an item is to decide which operations will be manual and which CNC. The decision depends upon time needed, number of parts, and practicality.
                  That's a nice set up Andrew, I don't think I'll be attempting anything like that for a bit! Last time I made bevel gears was as an apprentice many years ago! So for my set up to get me started I took a trip out to Chester tools yesterday (saw the new Beluga take off from Airbus as a bonus!) and bought a 80mm 3 jaw for £30 quid, which will hold stock accurate enough for a bit of rotary engraving. Next trip will be for a ER25 collet chuck plate for a set up similar to yours. I'll be using Vectric VCarve and Mach3.
                  Ian
                  #397207
                  John Haine
                    @johnhaine32865
                    I've never been comfortable leaving the CNC mill just getting on with things, probably through lack of faith in my own programming. But once, when I was making a collet tray from a lump of MDF with just a grid of holes, the code being generated by a CAM program (G_Simple since you ask), all went well until the last hole where it decided to do a G00 move (feed at max rate) down into the hole rather than G01 (move at specified feed rate). As far as I could tell that was the software which did that not me! No damage done fortunately, and was just wood (ish) not metal being cut.
                    But I remember getting very bored when the machine was engraving some nameplates – took over an hour per part!
                    #397237
                    Anonymous
                      Posted by Ian Johnson 1 on 20/02/2019 15:28:25:
                      My collets are 5C. I think the chuck was from MSC but the backplate is homemade. A point to bear in mind is that my custom version of Mach3 completely ignored feedrate values when combining rotary and linear movements in one line. For machining the worm I ended up using G93 – inverse time feedrate.
                      #397242
                      Anonymous
                        Posted by John Haine on 20/02/2019 17:42:08:
                        While it is facinating to watch I get bored so I leave the CNC mill to get on with it. I don't actually go out, but I'll make tea, work in the study or go outside and cut the grass. If a cutter is going to go ping I'm not going to stop it by watching so I might as well be productive elsewhere. The bevel pinion shown above took over two hours and some parts take four hours or more.
                        However I double check my CAM generated code. Experience says that the toolpath the CAM program displays is not always the toolpath the G-code produces. So I independently check the actual G-code with a backplotter program (NCPlot). This also has a useful feature of listing maximum excursions in all axes which is a quick and easy sanity check, especially when the work is mounted direct on the table.
                        #397249
                        Anonymous
                          Posted by John Alexander Stewart on 20/02/2019 15:16:39:
                          That's one way of looking at it, and I have used machine shops professionally that don't have any manual machines. But I wouldn't necessarily agree. I can definitely do some things quicker on the manual mill than on the CNC mill. I can also do things manually that I can't do CNC, either because of capacity/horsepower issues, or I can't create a 3D CAD model in the first place.
                          It could be a case of chicken and egg; after all if you don't have any manual machines available you wouldn't advocate using them. smiley
                          I've been looking at local university jobs with a view to going back to work in the university, albeit on the technical side rather than the academic side this time. The engineering department, Cavendish lab and Whittle lab have well equipped workshops with CNC machines, but also considerable manual machining capability. For many of the technician jobs CAD/CAM/CNC is listed as useful but not essential as training would be provided. So Cambridge at least seems to value manual machining skills.
                          #397264
                          Andrew Evans
                            @andrewevans67134
                            I use my KX3 in 1 of 2 ways. Its my only milling machine, I don't have space for a manual one as well and I use it for most drilling operations too. The first is for operations that could be just as easily done on a manual machine such as squaring off stock or cutting slots. For that I use G Code written straight into the MDI interface in Mach3. In that respect its like having an accurate, rigid, manual machine with a powerful spindle (for its size) with DRO and infinitely variable powerfeed on each axis. If you only ever used it like this then you aren't using it to its full potential but you don't lose anything either compared to a manual machine. Yes you have to boot up the PC and Mach3 but that is 30 seconds and it can be left on for hours if needed. It's relatively small so I can't do bigger jobs – thats the biggest drawback.
                            The 2nd way is designing something with CAD (I have only done simple stuff so far), using CAM to create GCode (or sometimes just writing GCode into a file by hand) and then running that code. That is probably something I do less of.
                            Regarding leaving it to work and doing something else – I do potter about the workshop when it is working and keep an eye out but I haven't felt confident enough to walk out completely. I made a mistake once and was just in time to jump over and hit the e-stop button before any real damage was done to the machine.
                            #397285
                            duncan webster 1
                              @duncanwebster1
                              If any of you proud new KX1 owners wants a stand for it, a friend of mine has one from a Chester Champion which needs a new home. The buyer of the milling machine didn't want the stand. As soon as I can get across to see him I'll measure it up and put more info in the classifieds. In the meantime if you want to put your name against it send me a pm
                              Edited By duncan webster on 21/02/2019 10:01:53
                              #397288
                                Likewise if anyone wants a stand for the larger KX-3 or that sort of size mill, give Ian a call at ARC as I declined the one with the machine that came to me, I'm sure they will do a good deal on it.
                                #397296
                                blowlamp
                                  @blowlamp
                                  The best recommendation I could make for anyone getting a CNC milling machine (or CNC lathe), is to acquire some good CAM software to go with it.
                                  It'll make life much easier and allow you to tackle jobs that are beyond the average person to code by hand.
                                  Martin.
                                  #397342
                                  Ian Johnson 1
                                    @ianjohnson1
                                    I agree Martin good CAM software is a must for CNC. When I got the KX1 it came with free full versions of Vectric Cut2D and Mach3, I found Cut2D dead easy to use and intuitive so a few months ago I upgraded to Vectric Vcarve desk top which is even better.
                                    Ian
                                    #397358
                                      So am I being a numpty and missing something obvious.
                                      Bought a recon XP Dell, loaded the included Mach3 disc and all seem to go well, rebooted when suggested and the test went through fine. I'm assuming the demo disc will allow me to run so long as below 500 lines. Can't register on Small CNC Support and have not signed up for anything on Mach3 site.
                                      Plugged into mill (USB on this machine) selected KV-3 5000 and Mack3 seems to come up as it should, clicked the reset and then thought I would see if things moved so hit tab to bring up the job panel. If i click the jog buttons the DROs move on the screen but nothing on the machine, if I hit the e-stop on the machine it does not do anything to the screen.
                                      If I load the code for the Sieg logo and start then it all runs on the screen but no movement on machine.
                                      Any ideas?
                                      #397365
                                      John Haine
                                        @johnhaine32865
                                        Have you loaded the Mach3 plugin for the usb controller?
                                        #397368
                                          No
                                          Manual seems to be for the parallel port. Will have a look to see if the plugin was one of the files on the supplied disc in the morning.
                                          Thanks, J
                                          #397391
                                          Ian Johnson 1
                                            @ianjohnson1
                                            Hi Jason, just a bit of info for you. Not sure why your machine won't move but if it helps my KX1 came supplied with a combined Mach3 and Sieg set up disc from Arc Euro who also supplied me with a separate emailed licence file for Mach3 (they are a third party supplier of Mach3 and can issue licences) this is a little file called 'Mach1Lic.dat' . This must be inserted (by copying and pasting) into the main Mach3 file. This will unlock the full Mach3 program and remove the line limit.
                                            The set up disc will also include the Sieg Kx1/Kx3 screen set to operate the machine, and you will also need another little file called 'Sieg_USB_ setup_1.6.0.0'. this will unlock the necessary operating system for USB connections. Again this must be copied and pasted into the Main program. This file could be downloaded from SmallCNCsupport but no longer! You'll know if it is the right screen set by looking at the bottom right of the screen it should say KX1 USB or KX3 USB. If you can't get hold of this file I can send it to you.
                                            Hope this helps
                                            Ian
                                            #397395
                                            Former Member
                                              @formermember32069
                                              #397402
                                              blowlamp
                                                @blowlamp
                                                If the DROs in Mach3 are moving, then it just sounds like a comms issue between computer and mill. There must be a USB driver that needs installing or setting up.
                                                Martin.
                                                #397416
                                                  Thanks Ian, will have a look later as I'm out on site this morning, may sneak a look before.
                                                  Barrie, yes I did click the reset (was in my post earlier), stops the message at the side flashing but as its a on screen e-stop stays red. Also looked at e-stop and chuck guard on machine. EDIT goes green around the outside when reset.
                                                  Martin that is what I'm thinking a sit does the same things with the USB lead pulled out.
                                                  J
                                                  Edited By JasonB on 22/02/2019 08:02:01
                                                  #397419
                                                  John Haine
                                                    @johnhaine32865
                                                    I don't know anything really about the KX mills, but I do use Mach3, so this suggestion may or may not be useful. My breakout boards have both parallel port and USB cables, the parallel carries the important signals and the USB is just there to power the input side of the opto couplers.
                                                    #397423
                                                      Thanks John but machine only has USB input, no parallel socket
                                                      This is what I have in the corner of the screen, no mention of USB
