Knurling tool
Knurling tool
Home Forums General Questions Knurling tool
  • #639831
    Graham Meek
      @grahammeek88282
      The problem with all these types of caliper knurling tools is the Overhang. The adjuster placed between the pivot point and the knurls reduces the capacity for a given size.
      In true Blue Peter style here is one I made earlier.
      The adjustment is near the operator, out of harms way. Due to the force application point there is an actual mechanical advantage over the standard caliper knurl. The arms holding the knurls are much shorter thus they do not magnify the sideways movement. Not that hey can move sideways due to the construction used.
      Capacity 0-50 mm, and it works straight out of the box, hence why I make my own tooling.
      Gray,
      Robert Atkinson 2
        @robertatkinson2
        Posted by Graham Meek on 01/04/2023 13:02:47:
        Gray,
        Hi Gray,
        You should write it up as an article for MEW.
        #639840
        Clive Brown 1
          @clivebrown1
          I made one borrowing from the Hemingway and Harold Hall designs. I liked the idea of the plates adding side support to the arms. This seems to work well in practice. Mine is sized for my Boxford. The knurls are 25mm dia. from Arc, which are perhaps a bit larger than most. The rest is mainly from material "in stock". Maximum working diameter is 50mm.
          #639853
          Vic
            @vic
            This is the one I made from materials I had to hand.
            #639932
            Graham Meek
              @grahammeek88282
              Posted by Robert Atkinson 2 on 01/04/2023 13:06:09:
              Hi Gray,
              Hi Robert,
              I wrote this up as an article with EiM back in Nov 2013, pages 149-153.
              I may well have submitted this to MEW many years ago, but I do not recall it being published. I know I have several items still waiting to be published with MEW, this may be among them.
              Unfortunately the timescale between submission and actual printing does nothing to help with my memory.
              Gray,
