Posted by John Olsen on 25/05/2016 01:29:36:
Usually this sort of thing goes a bit slow because one gets distracted into reading other articles.
I think actually ETW was one of the finest contributors ME has ever had.
Thanks John,
I feeling less guilty about you doing all this if you are finding plenty of other things to enjoy reading as a result!
I 100% agree with you about ETW. People don't appreciate the range of his work because he used so many pen names: Kinemette, Artificer and Ned for a start.
For some reason 'worn out' evaporust is doing an excellent job on the castings, which now reveal themselves to be sand castings. The white deposits are coming off as a dusty cloud and the darker ones are then rubbing off with a scratchy or a nylon brush on the dremel for tight corners.
The steel parts have all come up usable, There is only one significant but small patch of pitting on the liner, and it's low down so I have ordered a hone to see what happens. It may not even be above the top piston ring so if that's the case and it doesn't cause wear it shouldn't cause problems. the upper 2/3 of the liner look grey but smooth now.
The brass ring on the entry to the venturi came up well too.
