Posted by AndyP on 03/11/2012 11:06:58:
I note you said 22" diameter, does this mean it is a 'top loader'? – typical for a hobby level pottery kiln.
If so be warned that classicaly we load and unload a furnace hot unlike potters and a top loader is particularly unpleasant (some would say downright dangerous) to use that way.
A kiln with a door on the front is a much better proposition for our use.
You would want it to come with its controller because they can be bit spendy as well.
Andy
This does indeed sound like a typical ~ 1 cubic foot setting-space top-loading pottery kiln (I have one in my garage). They cost around the £1100 mark new these days, depending on whether a controller/thermocouple is included & how sophisticated the controller is. The modern ones will generally fire to 1300 Celsius (stoneware/porcelain firing temperature), so this one may be an older design.
If you are lucky, it will have an electronic controller that allows you to control ramp rate up to temperature, soak time at temperature, and ramp rate on cooling, which could have useful applications in metal shop use. Be aware though that pottery kilns almost invariably have exposed heating elements – in a top loader like this the elements would be carried in horizontal grooves in the side walls of the kiln. Obviously, touching these with metal objects when the kiln is powered on would not be a smart move, either for the operator or for the kiln.
Tony
Edited By Tony Jeffree on 04/11/2012 17:32:28
