I think my concern was addressed by a couple of the posters mentioning a) locating the phase / burst controllers on the output rather than the input of the transformer (I will need to check minimum working voltages) and the assymetry issue causing dc currents in the transformer.
I had considered the "cheap" E-Bay furnaces (1kg / 2kg capacity) but I read several comments suggesting the elements fail easily and you have to replace both element and central ceramic tube. I want to be running this at 1300C – at it's limit – hence my thinking of using my heavy duty wire to give it more robustness (shock resistance and longer oxidation resistance).
