Posted by samuel heywood on 13/03/2023 23:55:41:
Playing devils advocate~ have you considered a keyed chuck?
You don't say what machine it is intended to use this with but for your typical mini lathe/ mill i'd go with a keyed chuck any day~those keyless ones take up half the bed length on a small lathe!
Never owned a really good quality keyless but comparing like for like, a budget Rohm keyed tightens much better than a budget Rohm keyless IMHO.
Plus think of the endless amusement you'll miss out on not having to search for the chuck key.
That is why I use keyed chucks with cutters fitted (practically) permanently with my lathe. centre drill and small/large centre drills are in my “Quick change chuck” set. It is quicker to change the chuck than change the item secured within it.
These keyed chucks are old, reliable units and I can store the chuck keys where they won’t get lost! The keyless chuck is quickly and easily fitted for drilling.
As an aside, how much does run-out affect a chuck in the tailstock of a lathe? Rotating chucks, as in pillar drill or mill are a different consideration… but usually only result in larger holes than expected – which assumes perfect drilling machine and bits as well.
