Need to isolate the cause before spending any lovely money.
The fact that the motor starts and only stalls when a cutting load suggests it may be OK, that is the problem is caused by something else, perhaps in combination. Some suggestions, apologies if teaching Granny to suck eggs:
- Operator Error:
- Big blunt drill and a difficult material, like work-hardening Stainless steel. (A small blunt drill should spin without cutting.)
- Drill jambing whilst trying to open up a largish pilot hole.
- Big drill in wrong gear (spinning too fast, with low torque, causing a stall.)
- Drive-train fault, causing binding or wedging when pressure is applied:
- Mis-assembly by previous owner
- Broken bearing(s)
- Problem in the sliding part of the quill.
- I notice this is a nice machine with back-gear in addition to the usual belt change, but it's another thing to go wrong – has to be set up correctly, and the mechanism might be damaged.
Operator error is unlikely if Alan is experienced: I mention it just in case.
I'd proceed by disconnecting the power and taking the cover and belt off. Does the motor turn freely by hand? If the motor seems OK, concentrate on the drive train. Do the quill-side pulleys turn easily without any sign of trouble, and as the quill is moved up and down? Does the back-gear engage and disengage correctly. With a rounded end rod in the chuck for low friction when pressed on a plate, does the spindle turn freely when down pressure is applied, or does it bind up? If it binds, time to dismantle the quill looking for wear, bent parts, bulging, lube failure damage, bust bearings etc.
Perhaps a motor expert could comment on what sort of faults can cause a single-phase motor to start and run normally, but then stall easily. Outside my limited practical experience, which is single-phase motors suffer start problems due to capacitor or centrifugal switch failures rather than loss of power once running. The previous owner's report of belt slipping could be consistent with high drive-train friction before cutting starts.
Good news: lathes.co.uk says these machines are easy to work on and spares are available.
Edited By SillyOldDuffer on 27/03/2022 10:18:50
