Kerry Lathe Tool Post
Home Forums Help and Assistance! (Offered or Wanted) Kerry Lathe Tool Post
  • #34270
    Matt Morgans
      @mattmorgans60576
      Looking for a quick change tool post for a Kerry AG Lathe
      Matt Morgans
        @mattmorgans60576
        Hi All,
        I've recently purchased a Kerry AG lathe which is in excellent working order. I'd like to replace the existing tool post with a quick change version and was wondering if anyone had gone through this process before I start investigating compatible options?
        Many Thanks, Matt
        #660072
        Martin Johnson 1
          @martinjohnson1
          There is a Kerry owners group on IO groups. You would be welcome.
          Martin
          A confirmed 4 way toolpost diehard.
          #660098
          Diogenes
            @diogenes
            (Well look at that, after three years or something, I've found my original login)..
            Looks like the Kerry might use a T-slotted topslide, if that's the case a wedge- or piston- type 'Aloris' (or clone) should be a fairly straightforward 'slide-in' unless the Kerry uses some obscure 'nut' size – these toolposts mostly come with a stud and large flat T nut as standard, originally intended to replace the lantern-style toolposts that were then still common in the US..
            I'm sure you'll find dims. somewhere on the 'net.
            The wedge-type is a good toolpost, solid and repeatable in use, with cheap to buy / easy to make holders..
