Karcher pressure washer
Home Forums Help and Assistance! (Offered or Wanted) Karcher pressure washer
  • This topic has 22 replies, 13 voices, and was last updated 9 May 2023 at 17:07 by larry phelan 1.
Viewing 23 posts - 1 through 23 (of 23 total)
  • #423244
    BOB BLACKSHAW 1
      @bobblackshaw1
      My Karcher pressure washer which is around 25 years old gave up this week.
      The problem is that the motor is working but is not pushing out the pressure, it was working fine on the job I was doing then gave up.
      When the motor is pumping it now pushes out slightly more than when on mains water pressure
      Is this a simple fix or time to buy a new one, its not had a lot of use over the years still in the original box.
      Thanks Bob.
      BOB BLACKSHAW 1
        @bobblackshaw1
        #423250
        Howard Lewis
          @howardlewis46836
          If the motor is running, it sounds like the problem could be.
          Loss of drive to the pump. or Pump failure. (possibly stuck parts die to prolonged lack of use )
          This may be no more than the vanes have stuck, if a rotary pump.
          If a reciprocating pump, it may be that the piston rings have stuck / corroded.
          Could be no more than sticking valve/s
          Hopefully, freeing off the stuck parts will not be too difficult, and it will be restored to actiuon.
          Edited By Howard Lewis on 09/08/2019 11:00:43
          #423251
          Former Member
            @formermember32069
            #423258
            Bazyle
              @bazyle
              Beware if disassembling the pump that it is full of oil.
              #423273
              Joseph Noci 1
                @josephnoci1
                I have a large one, diesel fired to heat the water as well, when desired. It does (rather, 'did' ) not get much use, and that caused the problem. On mine the pump has 4 pistons affixed to a swashplate that the motor turns directly. That whole assembly is in oil. The pistons pass through a wall to the water side of things, with a rubber seal on both sides of the wall, one in oil, one in water then into ceramic pressure cylinders. When the pump stands for weeks, the water dries out in the chamber ( runs out, dries out, etc) and the next start the pistons run dry in the water jacket side rubber seal for a short while, and the seal wears out much sooner. Then the water is simply moved around inside the water chamber, from cylinder to cylinder, and nought exits the pressure valve – hard to explain the exact geometry, but sound seals are the key..
                The vendors sells a kit which includes pistons, all seals, some 'O' rings, etc and it took maybe an hour to make like new. Now I use the machine much more often…
                Joe
                Edited By Joseph Noci 1 on 09/08/2019 12:04:37
                #423274
                not done it yet
                  @notdoneityet
                  Mine gave up recently. The two of the three non-return valves were jammed open. There were lumps of dried scale, which had presumably slowly grown bigger over the years.
                  Carefully cleaned them out (the valves are fairly frail) with a pick and away it went. New valves are not too expensive and I think many pressure washers are discarded rather than being repaired. Plastic pumping heads are likely less worthy of repair – so much for the throw-away society of the present day!
                  The older pumping heads were far better than those on most modern cheap sets. They will likely withstand hot water . Mine has a metal pumping head – most are plastic these days.
                  Usual precursor to valve failure is that the pump restarts too regularly – the pressure switch holds it off at full pressure, but back-leakage causes regular motor restarts – not so good for a capacitor motor when every few seconds. Eventually the valves just don’t even allow pressure to be attained.
                  Bazyle is right with his warning. Keep it vertical (upside down) when removing the pumping head!
                  Soaking in warm/hot citric acid solution may be enough to dissolve the lumps, or at least a preventative maintenance job at regular intervals, if located in a hard water area.
                  #423321
                  BOB BLACKSHAW 1
                    @bobblackshaw1
                    Thanks for the replies,
                    I will have a look this weekend and see what's going on.
                    I was suppressed how cheap they are to buy new, easy to become a throw away society member.
                    Bob.
                    #423375
                    Nick Clarke 3
                      @nickclarke3
                      Mine doesn't get used much (just look at the state of my car for confirmation!) but if it does not spray splitting the Lance in two and using the pricker on the jet itself will usually bring it back to life.
                      Just a suggestion before you get too far into the entrails if your machine.
                      #423378
                      not done it yet
                        @notdoneityet
                        Posted by Nick Clarke 3 on 09/08/2019 20:45:04:
                        That will show the following signs (or is it symptoms?).
                        Motor will start initially to raise the pressure. Motor should then stop on the pressure switch and fail to restart for some time (dependent on the state of the valves).
                        Not the same as the OP is experiencing.
                        #423402
                        Mike Poole
                          @mikepoole82104
                          I bought a pressure washer when I got a car with alloy wheels, the novelty soon wore off and now I have a car with dirty alloys occasionally cleaned by our hard working car washers from the EU.
                          #423409
                          Kiwi Bloke
                            @kiwibloke62605
                            It should be an easy fix. My >30-year-old Karcher HD 575 is still going strong, but has always had a problem where pulling the trigger doesn't always release more than mains-pressure water. Usually, after a few trigger-pulls, or a bit of a wait, it is fine, only to 'fail' the next time the trigger is released. Or not… Annoying. Due, I'm sure, to it not being used enough, so evaporation of the water inside leaves the solids to gum up the works. The cure is to remove, dismantle and clean the pressure-adjusting valve. A smear of silicone grease helps. Similar attention to non-return valves, as above (NDIY), might also be necessary. The pump also piddles water out from the pump body drain orifices. This is because the piston seals wear. It's all an easy fix – assuming spares are available (here, in NZ, I'm not hopeful).
                            The pump is easily dismantled, without worrying about oil, orientation, etc. The swashplate assembly, between pump and motor, is oil-filled, but does not have to be disturbed for pump maintenance.
                            Repair, don't replace!
                            #423415
                            pgk pgk
                              @pgkpgk17461
                              Posted by not done it yet on 09/08/2019 21:06:00:
                              Signs = what is observed
                              Symptoms = what the patent feels (subjective)
                              I'm retired, I should keep my mouth shut…
                              pgk
                              #423416
                              not done it yet
                                @notdoneityet
                                Posted by pgk pgk on 10/08/2019 06:51:13:
                                pgk
                                I know. They were definitely signs to the owner, but are they then symptoms when the owner posts them on here?! smiley
                                #423418
                                Clive Hartland
                                  @clivehartland94829
                                  One aspect about power washers is that when used and put away they are left overwinter in a side shed. It freezes and the freezing water damages the pump.
                                  Next door had this happen, as they are cheap he threw it away.
                                  #423423
                                  pgk pgk
                                    @pgkpgk17461
                                    Posted by not done it yet on 10/08/2019 07:48:36:
                                    Yeah… but that would be his symptoms (sadness, ennui, financial anguish…) not the washer's laugh. But doubtless a case for compensation from kaarcher for the mental distress, especialy if he can claim to be a minority such as an investment banker with too much money and a coke habit.
                                    #423427
                                    Joseph Noci 1
                                      @josephnoci1
                                      And there the Forum Falls Foul of Flexiloquent Folk partaking in a Floccinaucinihilipilification process….
                                      Joe
                                      #423436
                                      pgk pgk
                                        @pgkpgk17461
                                        Posted by Joseph Noci 1 on 10/08/2019 09:04:58:
                                        Joe
                                        Serendipitous and beats the phrase I found last week of "Pucillanimous and pestiferous paltroonery' (which I'm still trying to slip into a pub conversation)
                                        #423443
                                        Kiwi Bloke
                                          @kiwibloke62605
                                          'And there the Forum Falls Foul of Flexiloquent Folk partaking in a Floccinaucinihilipilification process…."
                                          Our grandiloquent friend is surely mistaken: there was no ambiguity nor worthlessness opined. Pedantry perhaps, but correct usage of vocabulary seems to be a vanishing ability.
                                          #423463
                                          Ian S C
                                            @iansc
                                            Not sure where you are Kiwi Bloke , but there are Karcher outlets in Auckland, Hamilton, Wellington, and Christchurch.
                                            Ian S C
                                            #423472
                                            Joseph Noci 1
                                              @josephnoci1
                                              Posted by Kiwi Bloke on 10/08/2019 10:01:17:
                                              I was wondering where the worth was in :
                                              And the various bits of similar ilk, to the chap trying to find some help with his pressure washer…So , yes, rather worthless…and the vocab seems quite apt.
                                              Joe
                                              #423560
                                              Kiwi Bloke
                                                @kiwibloke62605
                                                Apologies to anyone who finds pedantry tiresome. The correct usage of the word means the only person practicing floccinaucinihilipilification in this thread is the person who considers content to be worthless. The two accused did not.
                                                If the forum were to restrict content to important, worthy and non-trivial content, there would be far, far less to enjoy.
                                                #644557
                                                larry phelan 1
                                                  @larryphelan1
                                                  Suppressed Bob ??? Surely not !!!!cheekycheeky
