just starting a workshop, going to build a steam locor
Home Forums Introduce Yourself – New members start here! just starting a workshop, going to build a steam locor
  • #40840
    martin sampson
      @martinsampson87875
      3 phase
      martin sampson
        @martinsampson87875
        hi just converted the garage and back room (somewhat) scrounged begged and bought some machines, bridgeport, boxford lathe, tool grinder, surface grinder, saw, pantagraph, various small bits some 110 not problem some 3 phase and some single got a couple of converters various results runs the motor on the lathe but only certain speeds if i fiddle with the boost, bought a VFD and motor not much luck got an electrician to have a look he couldn't see why waiting for a converter from machine mart to come as they tell me i wont have a problem lest i came take it back just wondered if i have a single phase on the chester mill, as the surface grinder i dropped the motor trying to lift it in the bench and bust all the castings….got a new single phase motor same speed and hp but is quite a jolt on start up would just like to here from someone who has got over these problems
        thanks hope it makes some sense sam
        #479157
        old mart
          @oldmart
          Welcome Martin, You have made a pretty good start with machinery, and there will be plenty of steam engine enthusiasts to guide you in your projects. This unfortunate CO19 lockdown has encouraged a lot of new members to make the effort to join the forum, its an ill wind…….
          #479165
          Brian H
            @brianh50089
            Hello Martin and welcome. Sounds like you are well equipped. What are you hoping to make with your machinery?
            #479608
              Welcome to the forum, Sam.
              Three phase will run smoother than single phase.
              A VFD will give the smoothest control fo all, and also less likely to overheat with repeated starts.
