Some engine owners I know have made steam-raising blowers (suckers?) by fitting old computer processor cooling-fans to a suitable adaptor for the chimney top. These have low-voltage d.c. motors, I think running at 12V.
This seems to work because the flue-gases exiting the chimney are not very hot, and by the time they do reach a temperature bad for the fan and motor, steam has been generated to a pressure at which the engine’s own blower can take over. That pressure will vary from engine to engine, but seems typically from about 20 to 30psi upwards.
The boiler does not want forcing by an over-enthusiastic draught anyway. For steam-raising the fire should be burning brightly and steadily, with the exhaust just past the smokey stage.
Steam-oils: Basically two forms, one for superheated steam, the other not. The viscosity does not seem to matter ever so much, at least I have never seen this specified. It is formulated to work by emulsifying in the steam so its viscosity does not have the significance it does in conventional bearings and i.c.-engine cylinders.
John –
Doesn’t anthracite used neat require quite a fierce draught to burn? (It is a coal with very low bituminous proportion.)
Noel –
Or soak the charcoal in meths. Though meths does create quite a bit of soot of its own. Domestic fire-lighters might work too though are very sooty. The proper wax type that is, not the new ever-so-sustainable sort that looks like rotted hardboard and burns just as badly (I have tried them!).
