Hi Peeps,
Just created an account. I'm an old geezer, well I started my Apprecnticeship as a Toolmaker in 1972, spent around 10 years in the industry doing some well known stuff and a lot of aerospace prototyping, lens / optics related stuff as well as some 'household names' e.g., if you ever had a BT type 706 telephone, you were holding parts made on press tools made by me, in your hand or if you had one of the ubiquitous pressure cookers with three triangular (with radiiused outer edges), chances are they were made on a press tool / made / repaired by me. Other works included parts for German Govt sponsored medical laser R&D.
Ended up in the Semi-Con industry and having retired (almost), have built my own little Toolroom, with a 8/28" lathe and a small vertical mill.
Current project is a Making / Fabricating a Surface Grinder from scratch with granite bedways / tables, ball-screws, linear rails and servo motors which will be driven be an SBC with pseudo-analog controls. So each control handwheel shaft will have a rotary encoder on it, which the SBC will convert to ball-screw motion, thus moving the tables and grinding wheel head height, adjustable in s/w for feed rate from quite quick (to emulate some of the best steel cable driven grinders to very slow for very fine positional accuracy, ideally giving me 1µm wheel downfeed when needed., let's see how it turns out…
The mechanical parts are mostly done (wheel spindle and drive, not yet) and the electronics / control still to be done. If it works out well, I had in my mind to make a Cylinder grinder after this but maybe not needed (I have a cutter grinder, so maybe it's overkill.
I'd be 'really' interested if anyone was daft enough / dedicated enough to do something similar/
All, the Best, Cheers, Martin.
