Boiler Making- Part 1:
I've decided enough is enough, it's time to stop worrying and preparing to extremes and finally make a start on the thing.
So I got to it and made the first cuts in the boiler shell/tube, ready for opening out. I ended up making the split line about an 1/8th off-center, parallel to the center line. This means that one side of the outer-firebox is the right length and the other side is slightly shorter, something I will cater for later on. If I had split the tube down the center line, the two side of the firebox would be equal lengths but would overall be shorter than the dimension specified by the drawing.
Next thing I did was make a wooden former to fit inside the boiler and give me something to shape the firebox with. To do this, I got a length of hard oak timber and cut it in half. I then glued and screwed the two halves together to give me a cuboid of suitable length and width for me to turn round. I then chiseled off the corners along their length to make turning the wood a little easier on the tools, the lathe and on my arms. After cutting grooves in the end faces of the block to locate the lathe steadies, I set the block up in the lathe. I then turned the block to a fitting diameter of the I/D of the boiler shell. I further turned a taper on one end of the block to make it easier to fit the block into the boiler shell. When this was done, I put the wood in the mill and machined a flat on the curved surface to take another block of wood the same size as the inside of the firebox. I found a suitable block and screwed it to the flat. This gave me a complete former.
After annealing the shell and pickling, I bent out the firebox sides so that I could fit the wooden former in the correct place. I then squeezed the firebox sides to the former as close as I could with my hands before squeezing it in the soft jaws of the vice. This gave a good shape and finish to the boiler shell.
Mechanical lubricator:
I've also bought and fitted a 1" square mechanical lubricator. I fitted it inside the chassis on the front buffer beam, inline with the gap between the steam chests. The lubricator is held up to the buffer beam by the stud on the towing hook. I've heard that the lubricator should be put on the running boards or in the cab instead of at the front because soot from the smoke box can fall in the oil tank when refilling or cleaning the smoke box. I decided against this purely because I don't want to see it and its easier to hook up to a moving part.
I bought the mechanical lubricator from a website called Steam Fittings. They have a good and extensive selection of relatively cheap yet high quality fittings.
I've compared a few websites for fittings and I've found a good list of sites. Below is my list and the best prices for certain fittings.
GLR Kennions- Pressure gauges and safety valves
Macc Model Engineers Supplies- Plain water gauges and blow down valves
Dave Noble- 3 cock water gauges (threaded to order)
Steam Fittings- Mechanical lubricator and clack valves
Dan.
Edited By Dan Jones on 01/07/2014 20:30:19
