Posted by Simon Collier 1 on 25/04/2016 22:39:20:
What sort of oil does one use? If the answer is "clock oil", what is it please? Also, is there a description somewhere online about how to clean and oil a clock motion?
Simon,
Years ago, 'Windles Clock Oil' was used, but that's now out of favour, and exotic synthetic oils by Moebius are generally preferred: **LINK**
Unless the movement is really dirty; Cleaning can usually be limited to 'pegging' the holes [using 'pegwood'] … You should find guidance if you Google those words.
Oiling should normally involve very small quantities at each pivot, and a mere touch on the escapement.
P.S. another specialist product is 'epilame' … which is a sort of resist, to stop oil spreading onto the plates … it is applied as a 'ring-fence' around the hole.
Edited By Michael Gilligan on 25/04/2016 23:13:53
