Hi Russell,
Thanks for your comments. I didn't make the pendulum bob as laid out in the book which is a quite streamlined design. Instead I used a piece of 40mm dia. steel 100mm long which has the same weight as I calculated the lead filled bob described in the book to have. The air resistance of this is going to be more than the bob described in the book which is only 25mm at its thickest point and 90mm in diameter. Although at this stage that's not what my problem is (there is barely enough ummph to keep the crutch alone oscillating) I'll bear it in mind if I make some progress in increasing the force from the escape wheel.
Yes, I initially ran it without oil as everything seemed to be rotating freely and I could drive the train by blowing on the escape wheel. Without oil I could only get a few beats out of the crutch but after I lubricated the pivots it more or less ran continuously.
You say I could try a heavier oil for the winding drum pivots. I have some clock spring oil. Would this be a better bet?
From what you say about lubricating the pallet faces, (which I didn't do) I presume one of the jobs to be done when I get it apart is to polish the contact surfaces of the escape wheel which still have the machined surface.
Hi Steven,
All of the small pivot holes are reasonably loose but the large diameter winding wheel pivots are a reasonably close fit. I'm not sure of the best way to ease these out as one end is an odd size which I needed to make a special reamer for.
The other area I'm not sure about is the adjustable front pallet bush. If this is rotated much, it binds onto the escape wheel pivot because the holes in the front pallet bush and the back cock aren't in line. This is made worse because of the thickness of the front bush. I've tried to get around this by drilling the hole out except for the back 1/8" but the amount of adjustment achievable before the pivots start to bind still isn't much.
As far as the lantern versus cut pinions go, one of the problems with lantern pinions is that you can't look at them end on to see how they engage with the wheels when you are depthing them. If I have the depthing wrong, I'm not inclined to plug the holes in the frame and start again. At some stage enough will be enough and I'll move on to a more rewarding project.
Thanks for the comments,
Alan C.
