Jessie and Bridget boiler
Home Forums Locomotives Jessie and Bridget boiler
  • #103572
    Ianmac
      @ianmac
      Evaluating a possible project and dont want to fork out the cash for 7 1/4 Bridget drawings at this early stage. I have a set of Jessie drawings.
      Is the boiler in Bridget the same as the unit fitted to Jessie?
      Ianmac
      Ianmac
        @ianmac
        #106499
        GWRdriver
          @gwrdriver
          Hello Ian,
          If I understand correctly you propose to build a Bridget. I can't provide a definitve answer to your question but I do know the Bridget boiler fairly well and it would be reasonable to assume that Ken Swan adapted at least the details if not the entire Bridget boiler to Jessie. From measuring two small elevation drawings the OA length and other major dimensions appear to be the same but that could very well be misleading. I would be glad to quote and compare OA dimesions with you if you wish.
          #106503
          Notlob
            @notlob
            Yes It is exactly the same boiler for both locos.I have built them both.
            regards Notlob
          Home Forums Locomotives Topics
