JC18A 7×12 minilathe chuck mount
  • #267756
    david williams 5
      @davidwilliams5
      Has anyone got any ideas on releasing a stcking chuck on amadeal cj 18A mnini lathlathe? David Willams.
      david williams 5
        @davidwilliams5
        sticking chuck
        #267759
          Hold a strip of metal against the head stock when you undo the chuck retaining screws so that they push against the metal as you undo them. Do this a little then rotarte chuck and do the next and so on. This will jack the chuck off the spindle nose.
          J
          #267774
          John Rudd
            @johnrudd16576
            Stick a decent piece of bar in the chuck to pull on……dont forget the obligatory piece of wood on the lathe bed….
            You could always warm the chuck with a hot air gun too…..
            #267784
              The register is only about 2.5mm long on a mini lathe, it really shouldn't be possible to jam it on. I assume you have all the nuts off…
              Put a bit of wood to protect the bed then tap it with a rubber mallet or a bit of wood and it should fall off – assuming you have undone the nuts.
              Just a thought – you do realise its bolted to the flange and the flange is a solid piece with the spindle?
