I have never considered model engineering to be a long painful experience, I,m afraid if I did I would be long gone. I think I have a reasonable level of patience but it's not unlimited.
I also have a DRO set on my mill, I have used laser cut parts and I use and am a big fan of JBWeld (original) but I don't think that means I am cheating. To date apart from flywheels I have not used castings but made parts from bar stock. Everyone to their own but for me producing quite complex parts from solid against machining a preshaped casting is far more satisfying and if that means a fillet of JB to give a cast look in places that's fine.
I have found JBWeld to be excellent, I have turned, it milled it, drilled and tapped it with no problems. I have used a couple of other metal filled epoxies but they were not as good as JB original. One of the things I also like about it, is its longer cure time I,m sure that gives a stronger joint/material than the rapid set types.
Edited By Ron Laden on 18/03/2021 05:52:03
