Hi Jason,
I would say the 7" pitch is a bit coarse for initial bench run's – it's always better to lightly load an engine – 4 or 5" pitch – keeping the revs up on a rich-ish mixture (for the cast in steel piston liner set up) but not allowing the head to get too hot – just about bearable with the bare fingers.
I've never used 'twenty year old fuel' but have used quite old stock for running in purposes. I have no idea whether the nitro would leach out but usually, if kept well stoppered it's okay. Sometimes the castor will precipitate into small white 'floaty' bits – not sure what causes this but it can play havoc with fuel settings and is best ditched. Methanol will absorb water too and that will affect performance but thats only really noticeable when you are looking for really consistent runs – eg in competition.
I recently bought a very cheap tacho off ebay – paid around a fiver including postage from Hong Kong and it appears to work okay though how accurate it is I have no idea. It was reasonably accurate to my bench drill at 4200 rpm and of course does give a good comparison prop to prop though. Only drawback is it reads both blades so the readings have to be divided.
Neil, it's only since doing the Eta engines that I have become aware that cast iron running in a leaded steel – En1a – liner is a very beneficial combination for piston and liner. Not wishing to contradict Jason but apparently many commercial engines have used this combination and obviously these are aimed directly at the flying model. I say apparently because the more I read on this the more this fact materialises
I know I go on about him but the writer of the article I found – George Aldrich – was a highly respected engineer who had much to do with engines used in world class control line speed events over many years. He wrote many articles on engines in the American model press and specialised in the piston/liner set up, indeed he later made a living from setting up engines for people world wide both for speed and control line aerobatic events. It the article he recommends the 'CIS' system – Cast In (leaded)Steel – as the better way to go up to a 1" bore, after which the weight of the piston becomes too much. For me it was all the confirmation needed to be sure it was the right way to go. Although written some time back I would say it still stands outside of access to some pretty esoteric kit and materials so I certainly see no reason now to step outside of using these two materials for any future 'home made' engines.
Good luck with your project whatever form it takes – don't forget the pics
Regards – Ramon
