Norman,
Don’t like small, takes too long
If I was re-incarnated as a vulture I’d be the first one to actually kill something !
I must admit that I do use studding a lot because of the ease of it, time saved and one length can make many different lengths. I can’t afford to stock studs in all different lengths and sizes plus have you costed commercial studs ?
Problem with running an emergency jobbing shop is that you need to have everything on stock, keeping 5 or 6 lengths of M5 up to M20 isn’t as bad as keeping every size of stud.
I do have to make the odd ones where they are stepped or waisted and I’m pretty well geared up for this as I have blank 5C collets pre threaded for M6 to M16 so I can grip on the pre threaded part without damaging the threads.
I know I can use split nuts etc but these will get lost, at least the 5C’s sit in the rack with the others.
John S.
