Hi all,
Did anyone do some experiments with back to basics point and coil ignition and timing yet?
I still think this may be the root of the problem. If you don’t have a healthy spark at exactly the right time any IC engine will run rough.
If the timing is right, with a healthy spark, the mixture can be very rich or lean with many engines and it will still run smoothly. The acceptable mixture range on some engines is quite large, for example the humble Briggs and Stratton 3.5 HP mower engines will run from a half turn to 2 turns on the mixture screw. That’s almost .060″ of needle movement! I’m just saying that adjusting the mixture to an ultra perfect precision is usually not necessary.
Good crankcase shaft sealing is important, but with the fixes already suggested re tight running fit, and grease, o-rings etc this will likely be OK.
Timing timing and then timing, I think.
JD
