So, John, did you get the engine to run? I followed this thread last year with a view to building one of these as soon as I finished the current project.
I have now completed the pressure controlled engine and, like you, can not get it to run.
From your experience, I built in an RCEXL CDI from the start so I know the ignition is ok. I have checked the ignition timing and it fires at 5 degrees BTDC which seems about right.
I have checked the mixture using a Colortune plug and I can adust it from rich to lean through the correct “bunsen blue” and the engine fires but will not run unaided.
It is not a free running as Jan’s, but it is certainly not excessively tight – about normal for an engine in fact.
Compression is 34 psi which is lower than I would hope, but not too bad.
Can you offer any advice?
Jim
