I've just finished the evening with a smirk on my face. The engine runs! It looks a right mess but it's going. Special thanks to Trevor, Ian SC, Howi and Gordon with apologies to anyone I forgot : there was overlapping good advice.
Problems fixed were:
- Displacer replaced with 4mm balsa and carefully fitted to the cylinder with a gap of 1 or 2mm. Adjusted to nearly hit the lower plate on the downstroke.
- Plasticine type modelling clay works as a sealant, at least as a temporary expedient. Wallace & Grommit taught me everything I know about making gadgets. Slight leakage was fixed by smearing extra clay into the outside gap between upper & lower plates and the acrylic tube cylinder.
- The flywheel was more carefully re-balanced with blobs of modelling clay in lieu of blu-tac. The engine went without doing this but the improvement was obvious. More needs to be done to the flywheel.
My coffee-cup is a vacuum type that holds heat much longer than an porcelain mug. At the moment the engine only runs on near boiling water. It goes for about 10 minutes. Don't ask how I know that it is still unpleasantly hot when spilled onto one's gentleman parts. I suffer for my art.
Before steps 2 and 3 it was obvious from the feel of the engine that it was in a better state. With heat applied It span much more freely in one direction than the other. In the forward direction a flick would result in up to 20 seconds of rotation, a significant improvement. Although the engine slowed down quickly I noticed that it was rolling gently past tdc rather more than could be explained by energy stored in the flywheel.
After fixing the minor leaks I spun the engine several times each time re-flicking it impatiently before allowing it to stop. After a fortuitous distraction I returned to find the engine still ticking over gently. It runs much more slowly than I expected – a stately 80 rpm dropping to about 45 rpm before stalling. Is this normal? I seem to remember seeing similar engines at exhibitions turning a lot faster. There will be no danger of it taking off when I add a propeller, ho, ho.
I shall have another go at it tomorrow. The flywheel isn't properly true and I think the balance can be improved. After more "running in" it needs serious cosmetic attention.
Thanks again,
