Jammed Motor Pulley on shaft of Myford Super 7
Home Forums Workshop Tools and Tooling Jammed Motor Pulley on shaft of Myford Super 7
Viewing 7 posts - 26 through 32 (of 32 total)
  • #162959
      Posted by CotswoldsPhil on 07/09/2014 19:08:21:
      … Did the pulley design change over time? as you all seem to be talking about only one grub screw being present.
      CotswoldsPhil
      Yes, Phil … I think it must have changed
      It seems there might be scope for some further improvement.
      Chris Trice
        @christrice43267
        In my Myford instruction book for the Super 7, although it’s a young machine, paragraph p on fitting the motor states, “.. line up the motor to it (the countershaft pulley) and lock the grub screwS which secure the motor pulley”.
        #162981
          The current Myford part is certainly illustrated with two tapped holes.
          Edit: Perhaps significant … according to lathes.co.uk the material was changed from Aluminium to Cast Iron.
          Note: My ML7-R has both of the "primary" pulleys in Aluminium.
          Edited By Michael Gilligan on 07/09/2014 22:05:03
          #162985
          Chris Trice
            @christrice43267
            Mine is cast iron with a single grub screw. My previous older machine pulley was aluminium but I don’t recall how many grub screws. I’m pretty sure the grub screw in the current one is smaller than the one that appears to have been used on the pulley this thread is about.
            #163034
              Adam,
              Returning to your original post, about making a puller for pulley removal
              I still don't know how many variants there are, but: I've just been cleaning-up my [single grubscrew] Aluminium pulley, and realised that the recess in the face is machined with an angled undercut … I wonder if there was a special puller that fit this?
              Adam Harris
                @adamharris13683
                Hi Michael, I am pressing ahead with my horse shoe but unfortunately I only have 13mm thick plate (!) so it is now a trip to toolstation to get a pack of thin cutting discs….
                #163043
                Gordon W
                  @gordonw
                  I would drill and tap two holes in the end face of the pulley while it is off. This can then be used with 2 bolts and a bit of bar the next time it needs to be off.
