Jaeger 4 day car clock
Home Forums Clocks and Scientific Instruments Jaeger 4 day car clock
Viewing 15 posts - 1 through 15 (of 15 total)
  • #296524
    Speedy Builder5
      @speedybuilder5
      I am searching for a replacement clock spring where both ends have snapped off.
      The "barrel" dia is 30mm, width 2.56mm and thickness 0.22mm.
      The inner attachment is via an elongated slot and the outer is bent back on itself.
      Anyone got a good idea where I can get a spring from?
      The photo is of a similar spring where the inner end snapped off.
      BobH
      Speedy Builder5
        @speedybuilder5
        Mainspring broken
        #296530
        Martin Kyte
          @martinkyte99762
          You could try
          or
          regards Martin
          #296536
          Speedy Builder5
            @speedybuilder5
            thanks Martin, but drawn a blank there. My other alternative is to make my own IF I can find a supplier of spring steel 2.56mm wide x 0.22 thick and 1.6 meters long.
            BobH
            #296537
            Martin Kyte
              @martinkyte99762
              In the interim could you not soften the ends and remake them. You end up with less run time but it would get you going again.
              regards Martin
              #296538
              Speedy Builder5
                @speedybuilder5
                I think it has been done a few times now.
                #296542
                Martin Kyte
                  @martinkyte99762
                  Ahh.
                  #296544
                  roy entwistle
                    @royentwistle24699
                    Could you not get a spring from one of the suppliers and modify the outer end?
                    Roy
                    #296553
                    Speedy Builder5
                      @speedybuilder5
                      Roy, neither of Martins suggested suppliers have this spring as standard section. I have asked Cousins to quote for a non standard spring.
                      2.56mm near enough 0.1"
                      0.22mm 0.009" (fairly thin stuff)
                      BobH
                      #296561
                      speelwerk
                        @speelwerk
                        google VOF van de gevel, they have a large selection under klok – veer. Niko
                        #296583
                        Speedy Builder5
                          @speedybuilder5
                          Niko,
                          lots of springs, but not nearly long enough – These are 36 hour springs I think – not that my Dutch is up to much.
                          #296597
                          speelwerk
                            @speelwerk
                            you can mail them and ask what the nearist is they have. 0.22 mm will be difficult to get, normal is 0.20 and then 0.25 mm. if you have acces to a surface grinder you can easily make the width smaller altough that leaves a very sharp edge that will happily cut your fingers during assembly. niko
                            Edited By speelwerk on 05/05/2017 20:58:02
                            #296598
                            V8Eng
                              @v8eng
                              You could try looking at the BHI Website, they list repairers maybe there is on in your area who could supply or help obtain materials.
                              I've put a link to the relevant pages here:-   http://bhi.co.uk/find-a/how-to-find-a-professional/
                              Edited By V8Eng on 05/05/2017 21:09:10
                              #296645
                              Speedy Builder5
                                @speedybuilder5
                                V8Eng
                                Thanks for the link – as you say there must be someone there. I had contacted a few before, but as soon as they hear Jaeger, they think I am rich and have a Bugatti car to go with the clock and somehow an Austin7 doesn't quite cut the mustard.
                                BobH
                                #296648
                                Brian G
                                  @briang
                                  It might be worth trying HS Walsh **LINK**
