Jacobs morse taper chuck.
Home Forums Workshop Tools and Tooling Jacobs morse taper chuck.
Viewing 23 posts - 1 through 23 (of 23 total)
  • #19827
    Jon Cameron
      @joncameron26580
      Jon Cameron
        @joncameron26580
        Is there a correct and easy method of removing a jacobs chuck from an arbour? Or once its pressed on is that it fixed.
        If so can anyone enlighten me please.
        Jon
        #480692
        larry phelan 1
          @larryphelan1
          Two wedges and a big hammer ?cheeky
          #480698
          Journeyman
            @journeyman
            Chuck removal wedges. Come in different sizes to match the JT taper:-
            Either use hammer or squeeze in the vice. Used as a pair, fit between the back of the chuck and the collar on the arbor.
            Edited By Journeyman on 18/06/2020 13:10:41
            #480701
            Martin Connelly
              @martinconnelly55370
              I have resorted to cutting off the bulk of the arbor, leaving enough to grip (a split collar can be made for this), and drilling out the core to reduce the pressure on the Jacobs taper The arbor is mainly soft so no problems drilling them. Recommendations for a new one is do not fit it with a press.
              Also check if there is a through hole in the chuck. You may be able to drive it out with a pin punch but I think the hole is very small and is to allow air to pass for assembly/disassembly.
              Martin C
              #480709
              ega
                @ega
                Most of mine are drilled through and tapped for a jack off screw. Obviously, you have to have done this in advance!
                #480713
                Brian Oldford
                  @brianoldford70365
                  +1 for folding wedges.
                  #480715
                  Simon Williams 3
                    @simonwilliams3
                    I managed to get one apart recently, having tried the wedges and failed, by drilling a hole down the centre of the arbour, into the void at the back of the chuck. I filled the hole with oil, then pushed a short piece of rod as a piston into the drilled hole. I was surprised how hard I found myself hitting the end of the piston to get the hydraulic shock enough to pop the taper.
                    And of course I was lucky it was a homemade arbour and had been left soft so I could drill down the centre of it.
                    Regards Simon
                    #480719
                    HOWARDT
                      @howardt
                      Drill chucks can be either held just on the taper, or sometimes held with an additional screw from inside the chuck. I just open up the jaws and place a bar inside and strike it to pop off the taper. In addition chucks can be screwed on like on portable drills.
                      #480720
                      Martin Connelly
                        Wedges will remove the chuck complete with arbor from the spindle. They will not separate the chuck from the arbor under normal circumstances unless the arbor is drawbar threaded. JT to MT arbors are usually tanged.
                        Martin C
                        Typical JT-MT arbor
                        Edited By Martin Connelly on 18/06/2020 14:24:23
                        #480721
                        old mart
                          @oldmart
                          By far the easiest way is to open up the chuck and select a drill which will pass between the jaws without touching them and drill into the void in front of the arbor. Then use the biggest punch that will go down the hole and knock the arbor off. I did one the other day, and still haven't found the arbor amongst the junk in my garage. The wedges are mostly a waste of time and money. Wedges would have to be used if the chuck is keyless, you cannot drill them without destroying them.
                          Electric drills which have reverse have a chuck which is screwed on. The screw down inside the chuck has a left hand thread to stop the chuck unscrewing when in reverse. The easy way to remove one of these after removing the screw is to put a large allen (hex) key in the chuck, tighten up and strike the end of the key with a mallet. Put the drill in low gear if it has one.
                          Edited By old mart on 18/06/2020 14:34:58
                          #480725
                          Journeyman
                            @journeyman
                            Chuck wedges are designed to go between the chuck body and the ridge/collar on the arbor, they are not designed to remove the arbor from the spindle.
                            In fact the splitting of chuck and arbor is probably better carried out away from the drill or mill.
                            There is also a circular wedge tool for the same job:-
                            Edit: Add image
                            Edited By Journeyman on 18/06/2020 15:22:21
                            #480727
                            old mart
                              @oldmart
                              That "circular wedge tool" is part of a bearing puller, and the tapered edge is designed to pull a ball race off something like a motorcycle crankweb.
                              #480731
                              Journeyman
                                @journeyman
                                Yes, indeed it is but can apparently be used for the job in hand. Can't say I have ever used one though!
                                Vic
                                  @vic
                                  I read many years from a chuck manufacturer to drill a hole through the back of the chuck and knock out the taper with a punch. Only needed to do it once but was surprisingly easy once you know.
                                  #480744
                                  old mart
                                    @oldmart
                                    Some other makes of chuck already have a hole, the one I did the other day had a hole the size of the end of the arbor, why Jacobs had to be different, I have no idea. We inherited an unused British made Jacobs chuck of 1/4" capacity on a MT1 arbor. We do have 1-2 adaptors, but I drilled it and fitted it to a MT2 arbor so it would fit the lathe directly, or the mills via a tang type R8 adaptor. It runs 0.0015" tir which is plenty good enough for us.
                                    #480833
                                    Jon Cameron
                                      @joncameron26580
                                      Hello,
                                      Thank you for all your responses, I have a Bearing pulley exactly like the one shown, i will give it a try first. failing that ill go down the drill and knock out route.
                                      The reason that i wanted to get the taper out is i believe the taper is bent and it doesnt run true when holding drill bits. I'll be mounting it onto a new arbour. If that doesnt work then i'll go down the route of buying a new one.
                                      Jon
                                      #480841
                                      Clive Brown 1
                                        @clivebrown1
                                        Before you take drastic action, can you mount the arbour and chuck on thedrill/ lathe spindle then check the chuck body with a DTI, ie the part in which the key-holes are drilled? If that shows run out, then it's good evidence that the arbour is in fact bent. If not then the chuck jaws could be where problem is.
                                        #480844
                                        Martin Connelly
                                          We had a big Asquith radial arm drill (MT5) where I worked and it regularly had a chuck swung into a vice or other solid lump. The arbors bent very easily when abused like this which was good as they are normally easily replaced. The point is, always assume the arbor is bent as a first action. This is also why I have experience of removing many of them.
                                          Martin C
                                          Auto correct corrected!
                                          Edited By Martin Connelly on 19/06/2020 10:18:12
                                          #480859
                                          mechman48
                                            @mechman48
                                            I have used the wedges to remove a chuck from my bench drill when changing from keyed to keyless chuck, they are awkward to get started but not difficult, I used a large 'G' clamp to push them together, they work efficiently, having checked on ArcEuro it seems that they no longer supply them, mores the pity as they were cheap enough, a couple of quid iirc, usual disclaimer applies.
                                            George.
                                            #480873
                                            Martin Connelly
                                              I have destroyed the morse taper on an arbor trying to remove it with bought wedges, I have also destroyed the wedges trying to do it. I made some wedges as well and destroyed them. I did manage to get one off with the open end of a combination wrench hammered in to the groove. I have had to drill a few out to remove them, it always works doing it that way.
                                              Martin C
                                              #480875
                                              David Davies 8
                                                @daviddavies8
                                                " I did manage to get one off with the open end of a combination wrench hammered in to the groove"
                                                Martin,
                                                I'm pleased to read that there are still a few of us craftsmen around!wink
                                                Martin Connelly
                                                  Wouldn't do it that way at home but at work with a cost rate over £70/hour getting the job going again and replacing a wrecked spanner was the cheapest option.
                                                  Martin C
