But did you scratch build the parts of the tank or just stick them together
Peter, they flywheel and final drive on a 2" are going to be around 9" in most cases so that is probably going to be your largest diameter if the wheel rims can be done buy rolling or using as "cast" rims, if not you are going to need 13" swing.
For the 2" Minnie very roughly
Castings £1750
Gear cutting if you can't do it £750
Copper, Bronze & Solder say £1000 add another £1500 to that if buying completed boiler
Sundry materials, fixings etc Say £500
Boiler fittings -3 cock water gauge, injector, few valves, clacks say £500
Tooling you don't have easily £500plus
4 years of weekends and evenings – Priceless
Edited By JasonB on 29/07/2018 10:35:25
