Issue 286 Spot drills
Home Forums Model Engineer & Workshop Issue 286 Spot drills
Viewing 25 posts - 1 through 25 (of 25 total)
  • #431213
    Ian P
      @ianp
      Moved thread
      Rather than start a new thread but since this one is morphing away from Andrew's specific article I thought I would make some comments on the current MEW 'Editors Bench' in praise of spotting drills.
      I am a fan of spotting drills but I have not yet found (but I'm sure they must exist?) 60 degree versions that can be used (with a truncated centre or drilled clearance) with standard 60 degree centres. Neil mentions 90 degree ones which are fine for spotting but as the article starts with discussing centre drills it give the impression that they could be used to put centre holes in for lathe work.
      Ian P
      Edited By JasonB on 30/09/2019 17:56:35
        I think the article is suggesting that spotting drills are better to use for starting a twist drill than a ctr drill not as a substitute when a 60deg hole for a ctr is needed.
        This is the way I use them only getting out a ctr drill when I want to put a ctr into the hole, all other times I use a spot drill. Think I have only seen 60deg ones as insert not solid.
        Edited By JasonB on 30/09/2019 17:54:45
        #38535
          Ian P
            @ianp
            I think two thirds of the article relates to lathe work and it does then focus on hole starting in general.
            I have done a quick search to find 60deg spotting drills that could be used for lathe centre work but the only ones I found listed as 60deg were actually 120degree!
            What I did stumble upon though has shown me that all along I have not been following the correct practice for using spotting drills prior to using a twist drill
            Link to spotting drill usage article
            Ian P
            #431226
            Martin Rock-Evans
              @martinrock-evans77799
              Interesting article Ian. However, I'm struggling slightly to see why the small angle spot drill is bad because it must have a similar effect to a centre drill or pilot hole in that the first contact will not be the centre of the drill?
              #431230
                Maybe the clue is in their mention of carbide drills which could possibly be a bit more fragile than HSS.
                I usually just make a small dimple with a 90deg spotting drill which is not really any different to a good old whack on a ctr punch. Could be more of an issue if you are spotting to near or even larger than the drill diameter.
                I did find several 60deg point solid spotting drills on the net but the only UK one I found was a bit pricey starting at about £40 for a 3mm dia one. I would also think the more pointed they are the more fragile so there may be less benefit if using to avoid broken ctr drills.
                Edited By JasonB on 30/09/2019 18:53:36
                #431235
                Ian P
                  @ianp
                  Fragile to the point of not making it worthwhile to use one (might be a pun there)
                  My thinking used to be that a conical spot-drilled hole would be good so the drill (smaller diameter than that hole) must start concentrically within it, now I am not so sure.
                  If the following drill does not have symmetrical cutting edges then the drill will (bend) be pushed over sideways (even if the job has not moved off the same location), and as the drill moves downwards to the point where the tip make full contact and actually starts drilling it may then start off centre. Obviously can only happen with a badly ground drill but whilst that same drill might drill oversize in a centrepopped or shallow angle spotdrilled recess, at least it will stay on the same centre.
                  Ian P
                  #431239
                  not done it yet
                    @notdoneityet
                    My question is: Why are centre (Slocombe)u drills that shape – a relatively long narrow (parallel?) start and a 60 degree shoulder?
                    The only sensible reason I can see is that of providing a lubrication reservoir for when using a dead centre. To provide clearance for the point of any centre would only need to be just a mm (or maybe the tips are longer to allow for resharpening by the user?).
                    #431270
                    Mark Rand
                      @markrand96270
                      Partly to provide a lubrication reservoir, but almost all because it's impossible to grind a drill with a pointed end, even a spotting drill has a very small flat on the end.
                      Of course, one could dub the end of the centre so it wouldn't bottom on a non-pointer hole.
                      The big advantage gained with spotting drills is that if the face is not completely normal to the drill or has any irregularity, a jobber or longer drill can walk around before cutting and then tart off centre. The spotting drill ensures that it won't do that.
                      Edited By Mark Rand on 30/09/2019 21:37:58
                      #431281
                      EdH
                        @edh
                        I use a 120 degree spot drill then drill with a 118 degree twist drill, this should ensure the central chisel edge of the twist drill contacts the metal first and not the lip as if it did this would probably throw the drill off centre if one of the lips started to bite before the other. I was led to believe this is why a 120 degree spot drill was produced.
                        Otherwise follow what JasonB does and make a small dimple and not a spot the size of the drill diameter.
                        #431290
                        Ian Johnson 1
                          @ianjohnson1
                          If you read the article carefully, you'll realise that Neil just wants a free drink! laugh
                          Ian
                          #431295
                          I.M. OUTAHERE
                            @i-m-outahere
                            I’m not sure if this was intentionally engineered into the design of centre drills but having that small extended hole in the bottom of a centre drilled hole gives a place to start a very small boring bar to true up or re cut a centre .
                            I think the guy on the Suburban tools youtube channel explained a few reasons for this extended hole in a video he made about lapping centres .
                            #431305
                            Martin Connelly
                              @martinconnelly55370
                              Is the theory of larger angles for spotting drills matched by something similar for centre punches? I have bought centre punches in the past that have been supplied with quite a blunt point ground on them. It may be that they are intended for drill positioning purposes where sharply pointed ones are not or that they are for larger drills with a wider chisel point.
                              Martin C
                              #431306
                              Martin Kyte
                                @martinkyte99762
                                Sharp angle punches are 'pricking punches' for picking up scribed lines. You can do this by feel once you have the knack. Followed by a centre punch you get a larger and wider angle hole to start a drill. Usual disclaimer of grandmothers and eggs etc.
                                regards Martin
                                #431317
                                Vic
                                  @vic
                                  Posted by not done it yet on 30/09/2019 19:41:58:
                                  I can answer that one. It’s so the tip breaks off the smaller sizes so you need to buy new ones! laugh
                                  #431320
                                  Martin Kyte
                                    @martinkyte99762
                                    Didn't Neil address that in the article. ? The 60 degree is so that the hole correctly matches the 60 degree centre for between centres turning and the pilot is to create clearence for the tip of said centre and to hold lubricant. In the past Slocombe drill were also used for creating starting holes for drilling but that is not their design purpose.
                                    regards Martin
                                    #431324
                                      Martin,
                                      I think ndiy’s query was based on his perception that the pilot portion appears unnecessarily long for its intended purpose.
                                        The extra length also allows resharpening in the vanishingly unlikely scenario of one lasting long enough to become blunt…
                                        old mart
                                          @oldmart
                                          A spotting drill with a 60 degree angle would not be suitable for use with centres as you could not be sure that the tip of the centre was not touching before the flanks. A standard centre drill ensures the flanks support the work rather than the tip.
                                          I only have 90 and 120 degree spotting drills, but would like 60 degree ones simply because it is easier to see where the point is before drilling. The 120 degree one masks the marking on the workpiece, and would work best if used after the initial spotting had been done.
                                          #431367
                                          MC Black 2
                                            @mcblack2
                                            Having read the Editors advice about using Spotting Drills rather than Centre Drills, I searched my collection of catalogues to find what companies sold Spotting Drlls – and drew a blank
                                            So I did an internet search with similar results
                                            Can anybody recommend a supplier of Spotting Drllls that do not require a bank loan to purchase, please?
                                            MC Black
                                            #431388
                                              MC, have a look at my second post in this thread for reasonably priced, reasonable quality ones. They are often cheaper than ctr drills of the same quality from these suppliers.
                                              #431400
                                              JonBerk
                                                @jonberk
                                                Has anybody successfully sharpened a Spotting Drill and if so how did they do it?
                                                I have tried, using a Picador grinding jig, and although I set the angle correctly the resultant shape was not as good as the original.
                                                Thanks
                                                Jon
                                                Edited By JonBerk on 01/10/2019 20:39:58
                                                #431527
                                                  Ideal candidates for four-facet point, I would have thought.
                                                  old mart
                                                    @oldmart
                                                    Those Europa Tool spotting drills are good quality ones, I have some.
                                                    #431733
                                                      Tracy Tools have got spot drills in stock, but not on their website. Give them a call (and tell them it was via MEW!) or there's a link here
                                                      Thanks to Pete Duckett for letting me know.
