Indeed, that's the one. Maybe one can shape the corners of the polepiece to prevent this?
If I may, just to close this topic off, I did mention earlier that it is known that the cycloid does not make a compound pendulum isochronous (and in fact there is no curve that can do that). My friend Andrew Millington (who is a real mathematician) has looked at this and come up with an approximation for the circular deviation of a compound pendulum moving in a cycloid, and also checked this against Woodward's analysis. This would apply to David's magnetically suspended pendulum as well as a pendulum with cycloidal cheeks. There are two factors to consider. One is the distance from the suspension point to the CoG of the whole pendulum, which is "r". The other is the "radius of gyration" which is a measure of the pendulum's "compoundness", which is "k".If the amplitude of swing is "a" radians, then the fractional change in clock rate is:
k^2.a^2 / [16(r^2 + k^2)]
If the pendulum is "simple" then k = 0, so the rate change is zero.
Suppose we want a 1metre pendulum. The bob weight can't be too large because it has to be supported by the magnet. So let's suppose it was 1kg. The "shoe" which has the circular face and contains the magnet needs steel polepieces and the magnet has to be strong and probably quite heavy. For the sake of argument suppose the whole shoe weighs 100g. Assume the rod is say carbon fibre and effectively weightless. Given the length of the rod and the weights you can calculate the position of the CoG and the value of k. Putting them in the formula and calculating gives a fractional change in rate of:
(+a^2/16)/13
For a normal circular pendulum the standard expression for CD is:
-a^2/16.
So while the CD is significantly less than for a conventional pendulum it isn't zero and can't be made zero. I think your suggestion and the experiments you did were very ingenious, but the fact that one does lose the "ideal" anisochnonicity (is that a word?) combined with the practical difficulties you've highlighted make this approach of theoretical interest only.
