Is this a dog?
Is this a dog?
Home Forums Workshop Tools and Tooling Is this a dog?
  • #582953
    AJAX
      @ajax
      I'm trying to figure out what this thing is. It's on a Morse taper (obviously) and the two outermost points have a spacing that lacks adjustment. I'm not sure what it could be used for other than maybe a drive dog of some sort. Perhaps it was made for a specific task? If anyone knows, I'd be interested to learn something new.
      20220123-211744 20220123-211750 20220123-211804 20220123-211810 20220124-202529 20220124-202538 20220124-202548 20220124-202735 20220124-202745
      AJAX
        @ajax
        #582954
        Chris Gunn
          @chrisgunn36534
          Could it be a trepanning tool?
          #582956
          AJAX
            @ajax
            Posted by Chris Gunn on 29/01/2022 19:47:16:
            I wondered that at first, but it seems to lack any useful adjustment. And those two points are not ground for cutting.
            #582957
            Clive Foster
              @clivefoster55965
              Given the different spacing of the two "points" from the centre I'd guess its for either:-
              marking out two concentric rings as a guide to further machining
              or
              cutting a large diameter but narrow washer from thin sheet material
              The points present don't look like cutting edges so making seems more likely.
              But its the sort of thing that could be a modification of a no longer needed device to do another job.
              #582962
              Dalboy
                @dalboy
                I have seen something similar but the two outer points do not have the sides ground away and also they are on the same plane not offset like your one.
                The one I had seen was designed for wood turning and gave a positive grip as a drive centre
                #582964
                MikeK
                  @mikek40713
                  Posted by AJAX on 29/01/2022 19:49:19:
                  Remove one of the "cutters" so that the cross bar can adjusted farther out? As mentioned, the "cutters" don't have any cutting geometry, though.
                  #582969
                  Martin Kyte
                    @martinkyte99762
                    Yes, I'd vote for woodturning driving dog too.
                    regards Martin
                    #582973
                    Ady1
                      @ady1
                      Yup. Wood.
                      #583008
                      Hopper
                        @hopper
                        Whistle and see if its ears prick up.
                        #583009
                        Mike Hurley
                          @mikehurley60381
                          I agree with Clive. Don't think they are woodturning dog – as he says they are not equidistant from the centre and appear to be adjustable – all wood dogs I've ever used are just on piece. These would appear more suitable for sticking in the tailstock and marking out rings or washers to be cut from stock held in the chuck etc.
                          regards Mike
                          #583022
                          Tony Pratt 1
                            @tonypratt1
                            Don't think it's a woodturning dog but as to what it is I'm not sure, the outer points are not very pointy or shaped for cutting.
                            Tony
                            #583023
                            Mark Rand
                              @markrand96270
                              It's also possible that it was used as an offset centre for taper turning.
                              #583025
                              Tony Pratt 1
                                @tonypratt1
                                Posted by Mark Rand on 30/01/2022 10:24:33:
                                How would that work? But maybe.
                                Tony
                                #583041
                                not done it yet
                                  @notdoneityet
                                  Posted by Hopper on 30/01/2022 09:42:10:
                                  My first thought was perhaps, a close relative of K-9.🙂
                                  #583133
                                    It's used in the headstock, and is a device for removing the ties of incautious machinists.
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi Neil, and one might very quickly see the point, close up! devil
                                      Regards Nick.
                                      #583210
                                      John Reese
                                        @johnreese12848
                                        I think it i a spur center for wood turning. Used in the headstock.
