Is there anyone who can roll me a small ring?
Home Forums Workshop Tools and Tooling Is there anyone who can roll me a small ring?
  • #99291
    David Clark 13
      @davidclark13
      Hi There
      I need a small ring rolling, steel about 3/32 to 1/8 inch (2 1/2 to 3mm) thick.
      About 55mm wide and 175mm diameter.
      Not quite full diameter would be fine.
      It is for a grinder guard.
      regards David
      David Clark 13
        @davidclark13
        #99399
        Peter Tucker
          @petertucker86088
          Hi David,
          Why not turn it from a piece of 2" galv pipe?
          Peter.
          #99400
          Andyf
            @andyf
            Think you may be confusing the 55mm length with the 175mm (six and a half inch) diameter, Peter.
            Sorry I can't help, David; I've no rolling machine..
            Andy
            #99401
            Ian Welford
              @ianwelford58739
              try a piece of steel ducting. Air con ducting off cuts are quite cheap / free and galvanised often.
              Regards Ian
              #99403
                Does it really need rolling, can you not bend it around something of a slightly less dia or use the 3 points in a vice method.
                J
                #99405
                Andy Freeman 1
                  @andyfreeman1
                  PM me with your address and I can post one to you tomorrow if you like, FOC. Will take only a couple of minutes to roll.
                  #99407
                  David Clark 13
                    @davidclark13
                    Hi There
                    All sorted thank you.
                    I can't do it at the moment and I need it before next Wednesday.
                    I don't have my workshop set up yet, that is what I am doing at the moment.
                    I thought I had better get it done before the year since we moved was up.
                    regards David
                    Edited By David Clark 1 on 25/09/2012 21:32:39
