Posted by DC31k on 24/03/2021 19:14:45:
Posted by SillyOldDuffer on 24/03/2021 17:31:18:
High-specification RSJs are sometimes made of exotic steels…
Could you give an example please of a 'high specification RSJ' and while you are at it, please give an example of a low or normal specification one just so we understand the distinction you are trying to make.
Structural steel will be either S275 or S355, properties for which, including machinability, will be easily found with the aid of a nearby Google.
Certainly!
As RSJs were being rolled long before S275 existed, a joist recovered from an old building might not be made of it. Not unlikely to be something similar but it could a plain carbon mild-steel. Bessemer didn't know about Manganese, and as adding it puts the price up, ordinary mild has been rolled as a structural steel. Pre-war British structural steel wasn't made to a standard at all – it varied by maker. Counterfeiting is another possibility.
At the 'better' end, I first heard of Nickel-steel RSJs being used in shipbuilding to save weight. Strong alloys are used in super-towers for the same reason. Like railway lines, they are made to order but stainless steel RSJs can be had for more ordinary purposes.
The comment came from my bad early experience with scrap, explained when I twigged there are thousands of different alloys out there, and many don't machine well. Unknown metals should be tested because it's unwise to assume anything. Great if scrap works, just be aware should trouble occur that not all metals machine well. The answer to 'Is RSJ steel machinable' is probably yes, but it has to be tried to prove it.
